BaseCamera.hh
Definition: BaseCamera.hh:41
T tan(T... args)
STL class.
virtual unsigned int RenderPassCount() const =0
virtual RenderPassPtr RenderPassByIndex(unsigned int _index) const override
Get a render passes by index.
Definition: BaseCamera.hh:734
double followPGain
P gain for follow mode. Determines how fast the camera moves to follow the target node....
Definition: BaseCamera.hh:233
virtual unsigned int RenderTextureGLId() const override
Get the OpenGL texture id associated with the render texture used by this camera. A valid id is retur...
Definition: BaseCamera.hh:704
bool equal(const T &_a, const T &_b, const T &_epsilon=T(1e-6))
static Matrix4< T > LookAt(const Vector3< T > &_eye, const Vector3< T > &_target, const Vector3< T > &_up=Vector3< T >::UnitZ)
virtual RenderTargetPtr RenderTarget() const =0
void SetTranslation(const Vector3< T > &_t)
math::Vector3d trackOffset
Set camera to track a point offset in target node's local or world frame depending on trackWorldFrame...
Definition: BaseCamera.hh:218
virtual bool SaveFrame(const std::string &_name) override
Writes the previously rendered frame to a file. This function can be called multiple times after Post...
Definition: BaseCamera.hh:410
#define ignerr
common::EventT< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> newFrameEvent
Definition: BaseCamera.hh:191
virtual void AddRenderPass(const RenderPassPtr &_pass)=0
virtual void * CreateImageBuffer() const
Definition: BaseCamera.hh:425
virtual common::ConnectionPtr ConnectNewImageFrame(Camera::NewFrameListener _listener) override
Definition: BaseCamera.hh:417
Vector3< T > & Pos()
virtual void SetFollowTarget(const NodePtr &_target, const math::Vector3d &_Offset, const bool _worldFrame) override
Set a node for camera to follow. The camera will automatically update its position to keep itself at ...
Definition: BaseCamera.hh:651
static unsigned int MemorySize(PixelFormat _format, unsigned int _width, unsigned int _height)
Get total memory size in bytes for an image with the given format and dimensions. If an invalid forma...
virtual RenderWindowPtr CreateRenderWindow() override
Create a render window.
Definition: BaseCamera.hh:457
double trackPGain
P gain for tracking. Determines how fast the camera rotates to look at the target node....
Definition: BaseCamera.hh:222
virtual void SetImageFormat(PixelFormat _format) override
Set the image pixel format.
Definition: BaseCamera.hh:300
virtual std::string Name() const =0
Get name of the render-engine.
virtual math::Matrix4d ProjectionMatrix() const override
Definition: BaseCamera.hh:467
virtual RenderEngine * Engine() const =0
Get the creating render-engine of the scene.
Definition: Image.hh:36
void Transpose()
virtual void SetAntiAliasing(const unsigned int _aa) override
Set the level of anti-aliasing used during rendering. If a value of 0 is given, no anti-aliasing will...
Definition: BaseCamera.hh:571
virtual unsigned int Width() const =0
virtual void SetImageHeight(const unsigned int _height) override
Definition: BaseCamera.hh:276
virtual void SetTrackPGain(const double _pGain) override
Set track P Gain. Determines how fast the camera rotates to look at the target node....
Definition: BaseCamera.hh:637
virtual unsigned int Height() const =0
double nearClip
Near clipping plane distance.
Definition: BaseCamera.hh:196
virtual void PostRender()=0
virtual double FarClipPlane() const override
Definition: BaseCamera.hh:578
static const Quaternion Identity
Definition: Camera.hh:40
virtual void Copy(Image &_image) const =0
Write rendered image to given Image. The RenderTarget will convert the underlying image to the specif...
static Quaternion< T > Slerp(T _fT, const Quaternion< T > &_rkP, const Quaternion< T > &_rkQ, bool _shortestPath=false)
virtual math::Vector3d TrackOffset() const override
Definition: BaseCamera.hh:623
virtual void Capture(Image &_image) override
Renders a new frame and writes the results to the given image. This is a convenience function for sin...
Definition: BaseCamera.hh:395
Pose3< double > Pose3d
math::Vector3d followOffset
Definition: BaseCamera.hh:236
Definition: Scene.hh:48
virtual void SetImageWidth(const unsigned int _width) override
Definition: BaseCamera.hh:262
virtual NodePtr TrackTarget() const override
Definition: BaseCamera.hh:616
virtual void RemoveRenderPass(const RenderPassPtr &_pass) override
Definition: BaseCamera.hh:720
virtual unsigned int AntiAliasing() const override
Definition: BaseCamera.hh:564
virtual unsigned int ImageWidth() const override
Definition: BaseCamera.hh:255
virtual void SetHFOV(const math::Angle &_hfov) override
Definition: BaseCamera.hh:543
virtual RenderPassPtr RenderPassByIndex(unsigned int _index) const =0
Get a render pass by index.
virtual void PreRender()=0
virtual double NearClipPlane() const override
Definition: BaseCamera.hh:592
virtual void SetMaterial(const MaterialPtr &_material) override
Definition: BaseCamera.hh:696
Prepare scene for rendering. The scene will flushing any scene changes by traversing scene-graph,...
virtual double FollowPGain() const override
Definition: BaseCamera.hh:689
Definition: RenderTarget.hh:37
virtual unsigned int RenderPassCount() const override
Definition: BaseCamera.hh:727
T clamp(T _v, T _min, T _max)
T atan(T... args)
Definition: BaseCamera.hh:307
bool followWorldFrame
Follow target in world frame.
Definition: BaseCamera.hh:229
double Degree() const
virtual math::Vector3d FollowOffset() const override
Definition: BaseCamera.hh:668
virtual math::Matrix4d ViewMatrix() const override
Definition: BaseCamera.hh:508
virtual void Copy(Image &_image) const override
Writes the last rendered image to the given image buffer. This function can be called multiple times ...
Definition: BaseCamera.hh:403
NodePtr followNode
Target node to follow.
Definition: BaseCamera.hh:225
virtual void SetAspectRatio(const double _ratio) override
Set the camera's aspect ratio. This value determines the cameras vertical field-of-view....
Definition: BaseCamera.hh:557
virtual VisualPtr VisualAt(const ignition::math::Vector2i &_mousePos) override
Definition: BaseCamera.hh:534
Shared pointer to Visual.
Definition: RenderTypes.hh:217
bool trackWorldFrame
Definition: BaseCamera.hh:214
virtual unsigned int ImageMemorySize() const override
Definition: BaseCamera.hh:283
virtual double TrackPGain() const override
Definition: BaseCamera.hh:644
T endl(T... args)
virtual void SetFollowPGain(const double _pGain) override
Set follow P Gain. Determines how fast the camera moves to follow the target node....
Definition: BaseCamera.hh:682
virtual void AddRenderPass(const RenderPassPtr &_pass) override
Definition: BaseCamera.hh:713
double farClip
Far clipping plane distance.
Definition: BaseCamera.hh:199
virtual PixelFormat ImageFormat() const override
Get the image pixel format. If the image pixel format has not been set with a valid value,...
Definition: BaseCamera.hh:293
virtual void Update() override
Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render...
Definition: BaseCamera.hh:386
shared_ptr< RenderWindow > RenderWindowPtr
Shared pointer to RenderWindow.
Definition: RenderTypes.hh:191
math::Angle hfov
Definition: BaseCamera.hh:205
virtual void SetFollowOffset(const math::Vector3d &_offset) override
Set offset of camera from target node being followed. The offset will be in the frame that is specifi...
Definition: BaseCamera.hh:675
NodePtr trackNode
Definition: BaseCamera.hh:211
virtual unsigned int ImageHeight() const override
Definition: BaseCamera.hh:269
virtual PixelFormat Format() const =0
virtual void PostRender() override
Preforms any necessary final rendering work. Once rendering is complete the camera will alert any lis...
Definition: BaseCamera.hh:369
Definition: BaseCamera.hh:44
virtual void SetWidth(const unsigned int _width)=0
virtual void SetFarClipPlane(const double _far) override
Definition: BaseCamera.hh:585
virtual double AspectRatio() const override
Definition: BaseCamera.hh:550
virtual void RemoveRenderPass(const RenderPassPtr &_pass)=0
virtual void SetTrackTarget(const NodePtr &_target, const math::Vector3d &_offset, const bool _worldFrame) override
Set a node for camera to track. The camera will automatically change its orientation to face the targ...
Definition: BaseCamera.hh:606
virtual math::Angle HFOV() const override
Definition: BaseCamera.hh:527
virtual Image CreateImage() const override
Created an empty image buffer for capturing images. The resulting image will have sufficient memory a...
Definition: BaseCamera.hh:376
virtual void SetHeight(const unsigned int _height)=0
virtual void SetTrackOffset(const math::Vector3d &_offset) override
Set track offset. Camera will track a point that's at an offset from the target node....
Definition: BaseCamera.hh:630
virtual void SetNearClipPlane(const double _near) override
Definition: BaseCamera.hh:599
virtual void SetFormat(PixelFormat _format)=0
unsigned int antiAliasing
Anti-aliasing.
Definition: BaseCamera.hh:208
Quaternion< T > & Rot()
virtual NodePtr FollowTarget() const override
Definition: BaseCamera.hh:661
