Geometry.hh
17 #ifndef IGNITION_RENDERING_GEOMETRY_HH_
18 #define IGNITION_RENDERING_GEOMETRY_HH_
20 #include <string>
21 #include "ignition/rendering/config.hh"
24 #include "ignition/rendering/Export.hh"
25
26 namespace ignition
27 {
28  namespace rendering
29  {
30  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
31  //
34  class IGNITION_RENDERING_VISIBLE Geometry :
35  public virtual Object
36  {
38  public: virtual ~Geometry() { }
39
42  public: virtual bool HasParent() const = 0;
43
46  public: virtual VisualPtr Parent() const = 0;
47
50  public: virtual void RemoveParent() = 0;
51
57  public: virtual void SetMaterial(const std::string &_name,
58  bool _unique = true) = 0;
59
63  public: virtual void SetMaterial(MaterialPtr _material,
64  bool _unique = true) = 0;
65
68  public: virtual MaterialPtr Material() const = 0;
69  };
70  }
71  }
72 }
73 #endif
STL class.
STL class.
virtual VisualPtr Parent() const =0
Get the parent Visual.
virtual void RemoveParent()=0
Detach this Geometry from its parent Visual. If this Geometry does not have a parent,...
virtual ~Geometry()
Deconstructor.
Definition: Geometry.hh:38
Definition: Object.hh:34
virtual bool HasParent() const =0
virtual MaterialPtr Material() const =0
virtual void SetMaterial(const std::string &_name, bool _unique=true)=0
Set the materials of this Geometry. The specified material will be retrieved from the parent Scene....
Definition: Material.hh:47
Represents a geometric shape to be rendered.
Definition: Geometry.hh:34
