MeshDescriptor.hh
17 #ifndef IGNITION_RENDERING_MESHDESCRIPTOR_HH_
18 #define IGNITION_RENDERING_MESHDESCRIPTOR_HH_
20 #include <string>
21
23
24 #include "ignition/rendering/config.hh"
25 #include "ignition/rendering/Export.hh"
26
27 namespace ignition
28 {
29  namespace common
30  {
31  class Mesh;
32  }
33 }
34
35 namespace ignition
36 {
37  namespace rendering
38  {
39  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
40  //
44  struct IGNITION_RENDERING_VISIBLE MeshDescriptor
45  {
47  public: MeshDescriptor();
48
52  public: explicit MeshDescriptor(const std::string &_meshName);
53
56  public: explicit MeshDescriptor(const common::Mesh *_mesh);
57
61  public: void Load();
62
65  public: const common::Mesh *mesh = nullptr;
66
69
74
76  public: bool centerSubMesh = false;
77  };
78  }
79  }
80 }
81 #endif
STL class.
Describes how a Mesh should be loaded.
Definition: MeshDescriptor.hh:44
bool centerSubMesh
Denotes if the loaded sub-mesh vertices should be centered.
Definition: MeshDescriptor.hh:76
std::string subMeshName
Name of the sub-mesh to be loaded. An empty string signifies all sub-meshes should be loaded.
Definition: MeshDescriptor.hh:72
std::string meshName
Name of the registered Mesh.
Definition: MeshDescriptor.hh:68
void Load()
Ensures both the meshName and mesh member variables have been assigned. If mesh is not null,...
const common::Mesh * mesh
common::Mesh object
Definition: MeshDescriptor.hh:65
