Object.hh
17 #ifndef IGNITION_RENDERING_OBJECT_HH_
18 #define IGNITION_RENDERING_OBJECT_HH_
20 #include <string>
21 #include "ignition/rendering/config.hh"
23 #include "ignition/rendering/Export.hh"
24
25 namespace ignition
26 {
27  namespace rendering
28  {
29  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
30  //
34  class IGNITION_RENDERING_VISIBLE Object
35  {
37  public: virtual ~Object() { }
38
43  public: virtual unsigned int Id() const = 0;
44
49  public: virtual std::string Name() const = 0;
50
53  public: virtual ScenePtr Scene() const = 0;
54
58  public: virtual void PreRender() = 0;
59
62  public: virtual void PostRender() = 0;
63
67  public: virtual void Destroy() = 0;
68  };
69  }
70  }
71 }
72 #endif
STL class.
STL class.
virtual void PostRender()=0
Definition: Scene.hh:48
virtual void PreRender()=0
virtual unsigned int Id() const =0
Get the object ID. This ID will be unique across all objects inside a given scene,...
virtual ScenePtr Scene() const =0
virtual ~Object()
Definition: Object.hh:37
Definition: Object.hh:34
virtual void Destroy()=0
virtual std::string Name() const =0
Get the object name. This name will be unique across all objects inside a given scene,...
