PixelFormat.hh
17 #ifndef IGNITION_RENDERING_PIXELFORMAT_HH_
18 #define IGNITION_RENDERING_PIXELFORMAT_HH_
20 #include <string>
21 #include "ignition/rendering/config.hh"
22 #include "ignition/rendering/Export.hh"
23
24 namespace ignition
25 {
26  namespace rendering
27  {
29  //
32  enum IGNITION_RENDERING_VISIBLE PixelFormat
33  {
37  PF_L8 = 1,
39  PF_R8G8B8 = 2,
41  PF_B8G8R8 = 3,
50  // Float32 format one channel
52  // Float32 format and RGB
54  // Float32 format and RGB
56  // 16 bit single channel
57  PF_L16 = 11,
59  PF_COUNT = 12
60  };
61
64  class IGNITION_RENDERING_VISIBLE PixelUtil
65  {
68  public: static bool IsValid(PixelFormat _format);
69
75  public: static PixelFormat Sanitize(PixelFormat _format);
76
80  public: static std::string Name(PixelFormat _format);
81
86  public: static unsigned int ChannelCount(PixelFormat _format);
87
92  public: static unsigned int BytesPerChannel(PixelFormat _format);
93
98  public: static unsigned int BytesPerPixel(PixelFormat _format);
99
108  public: static unsigned int MemorySize(PixelFormat _format,
109  unsigned int _width, unsigned int _height);
110
116  public: static PixelFormat Enum(const std::string &_name);
117
119  private: static const char *names[PF_COUNT];
120
122  private: static const unsigned char channelCounts[PF_COUNT];
123
125  private: static const unsigned char channelByteCounts[PF_COUNT];
126  };
127  }
128  }
129 }
130 #endif
Provides supporting functions for PixelFormat enum.
Definition: PixelFormat.hh:64
@ PF_R8G8B8
< RGB, 1-byte per channel
Definition: PixelFormat.hh:39
STL class.
PixelFormat
Image pixel format types.
Definition: PixelFormat.hh:32
@ PF_BAYER_RGGB8
< Bayer RGGB, 1-byte per channel
Definition: PixelFormat.hh:43
@ PF_FLOAT32_RGB
Definition: PixelFormat.hh:55
static unsigned int MemorySize(PixelFormat _format, unsigned int _width, unsigned int _height)
Get total memory size in bytes for an image with the given format and dimensions. If an invalid forma...
@ PF_BAYER_GBGR8
< Bayer GBGR, 1-byte per channel
Definition: PixelFormat.hh:47
Get enum value by human-readable name. The given string should match watch is returned by GetName....
@ PF_L8
< Grayscale, 1-byte per channel
Definition: PixelFormat.hh:37
@ PF_FLOAT32_R
Definition: PixelFormat.hh:51
Get number of bytes per pixel for given format. If an invalid format is given, 0 will be returned....
Get number of bytes per channel for given format. If an invalid format is given, 0 will be returned.
Get number of channels for given format. If an invalid format is given, 0 will be returned.
@ PF_B8G8R8
< BGR, 1-byte per channel
Definition: PixelFormat.hh:41
Get human-readable name for pixel format value.
@ PF_BAYER_GRGB8
< Bayer GRGB, 1-byte per channel
Definition: PixelFormat.hh:49
@ PF_L16
Definition: PixelFormat.hh:57
Sanitize given format. If the given value is invalid, PF_UNKNOWN will be returned,...
@ PF_FLOAT32_RGBA
Definition: PixelFormat.hh:53
Determine if given format is valid PixelFormat enum.
@ PF_UNKNOWN
< Unknown or errant type
Definition: PixelFormat.hh:35
@ PF_BAYER_BGGR8
< Bayer BGGR, 1-byte per channel
Definition: PixelFormat.hh:45
@ PF_COUNT
< Number of pixel format types
Definition: PixelFormat.hh:59
