RenderingIface.hh
17 #ifndef IGNITION_RENDERING_RENDERINGIFACE_HH_
18 #define IGNITION_RENDERING_RENDERINGIFACE_HH_
20 #include <list>
21 #include <map>
22 #include <string>
23 #include <vector>
24
25 #include "ignition/rendering/config.hh"
26 #include "ignition/rendering/Export.hh"
28
29 namespace ignition
30 {
31  namespace rendering
32  {
33  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
34  //
35  class RenderEngine;
36
39  IGNITION_RENDERING_VISIBLE
40  bool load();
41
44  IGNITION_RENDERING_VISIBLE
45  bool init();
46
49  IGNITION_RENDERING_VISIBLE
50  bool fini();
51
54  IGNITION_RENDERING_VISIBLE
55  unsigned int engineCount();
56
60  IGNITION_RENDERING_VISIBLE
61  bool hasEngine(const std::string &_name);
62
66  IGNITION_RENDERING_VISIBLE
67  bool isEngineLoaded(const std::string &_name);
68
71  IGNITION_RENDERING_VISIBLE
73
82  IGNITION_RENDERING_VISIBLE
83  RenderEngine *engine(const std::string &_name,
84  const std::map<std::string, std::string> &_params = {},
85  const std::string &_path = "");
86
94  IGNITION_RENDERING_VISIBLE
95  RenderEngine *engine(const unsigned int _index,
96  const std::map<std::string, std::string> &_params = {},
97  const std::string &_path = "");
98
102  IGNITION_RENDERING_VISIBLE
103  bool unloadEngine(const std::string &_name);
104
109  IGNITION_RENDERING_VISIBLE
110  void registerEngine(const std::string &_name, RenderEngine *_engine);
111
116  IGNITION_RENDERING_VISIBLE
117  void unregisterEngine(const std::string &_name);
118
122  IGNITION_RENDERING_VISIBLE
123  void unregisterEngine(RenderEngine *_engine);
124
128  IGNITION_RENDERING_VISIBLE
129  void unregisterEngine(const unsigned int _index);
130
133  IGNITION_RENDERING_VISIBLE
134  void setPluginPaths(const std::list<std::string> &_paths);
135
144  IGNITION_RENDERING_VISIBLE
146  }
147  }
148 }
149 #endif
STL class.
STL class.
std::vector< std::string > loadedEngines()
Get the names of all engines currently loaded.
Unregister a render-engine registered under the given name. If the no render-engine is registered und...
Unload the render-engine registered under the given name.
Register a new render-engine under the given name. If the given name is already in use,...
RenderEngine * engine(const std::string &_name, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
Get the render-engine registered under the given name. If no render-engine is registered under the gi...
bool fini()
Destroy all render-engines and related resources.
Determine if a render-engine is already loaded.
ScenePtr sceneFromFirstRenderEngine()
Most applications will only have one rendering engine loaded at a time, and only one scene within tha...
STL class.
bool init()
Initialized shared render-engine features.
void setPluginPaths(const std::list< std::string > &_paths)
Set the plugin paths from which render engines can be loaded.
Get the number of available render-engines.
bool load()
Load shared render-engine resources.
shared_ptr< Scene > ScenePtr
Shared pointer to Scene.
Definition: RenderTypes.hh:194
Determine if a render-engine is registered under the given name.
