ShaderParam.hh
2  * Copyright (C) 2017 Open Source Robotics Foundation
17
18 #ifndef IGNITION_RENDERING_SHADERPARAM_HH_
19 #define IGNITION_RENDERING_SHADERPARAM_HH_
20
21 #include <cstdint>
22 #include <memory>
23
25
26 #include "ignition/rendering/config.hh"
27 #include "ignition/rendering/Export.hh"
28
29 namespace ignition
30 {
31  namespace rendering
32  {
33  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
34  //
36  class ShaderParamPrivate;
37
39  class IGNITION_RENDERING_VISIBLE ShaderParam
40  {
41  public: enum ParamType : uint16_t
42  {
44  PARAM_NONE = 0,
45
47  PARAM_FLOAT = 1,
48
50  PARAM_INT = 2,
51  };
52
54  public: ShaderParam();
55
58  public: ShaderParam(const ShaderParam &_other);
59
61  public: ~ShaderParam();
62
65  public: ParamType Type() const;
66
70  public: ShaderParam &operator=(const ShaderParam &_other);
71
74  public: void operator=(const float _value);
75
78  public: void operator=(const int _value);
79
83  public: bool Value(float *_value) const;
84
88  public: bool Value(int *_value) const;
89
92  private: std::unique_ptr<ShaderParamPrivate> dataPtr;
94  };
95  }
96  }
97 }
98
99 #endif
Get the value of this parameter if it is a float.
Get the type of this parameter.
ParamType
Definition: ShaderParam.hh:41
@ PARAM_NONE
Type none.
Definition: ShaderParam.hh:44
a variant type that holds params that can be passed to a shader
Definition: ShaderParam.hh:39
ShaderParam & operator=(const ShaderParam &_other)
Set from another ShaderParam.
@ PARAM_INT
Integer type param.
Definition: ShaderParam.hh:50
@ PARAM_FLOAT
Float type param.
Definition: ShaderParam.hh:47
