ShaderType.hh
17 #ifndef IGNITION_RENDERING_SHADERTYPE_HH_
18 #define IGNITION_RENDERING_SHADERTYPE_HH_
20 #include <string>
21 #include "ignition/rendering/config.hh"
22 #include "ignition/rendering/Export.hh"
23
24 namespace ignition
25 {
26  namespace rendering
27  {
29  //
34  enum IGNITION_RENDERING_VISIBLE ShaderType
35  {
38
40  ST_PIXEL = 1,
41
43  ST_VERTEX = 2,
44
47
50
52  ST_COUNT = 5,
53  };
54
57  class IGNITION_RENDERING_VISIBLE ShaderUtil
58  {
62  public: static bool IsValid(ShaderType _type);
63
69  public: static ShaderType Sanitize(ShaderType _type);
70
74  public: static std::string Name(ShaderType _type);
75
81  public: static ShaderType Enum(const std::string &_name);
82
84  private: static const char *names[ST_COUNT];
85  };
86  }
87  }
88 }
89 #endif
STL class.
@ ST_NORM_OBJ
Object-space normal map shader.
Definition: ShaderType.hh:46
Get enum value by human-readable name. The given string should match watch is returned by GetName....
Sanitize given type. If the given value is invalid, ST_UNKNOWN will be returned, otherwise input will...
Get human-readable name for shader type value.
@ ST_NORM_TAN
Tangent-space normal map shader.
Definition: ShaderType.hh:49
@ ST_VERTEX
Per vertex lighting shader.
Definition: ShaderType.hh:43
Determine if given type is valid ShaderType enum.
@ ST_UNKNOWN
Unknown or errant type.
Definition: ShaderType.hh:37
Provides supporting functions for ShaderType enum.
Definition: ShaderType.hh:57
@ ST_PIXEL
Per pixel lighting shader.
Definition: ShaderType.hh:40
ShaderType
Available types of shaders. Note that not all rendering-engines will be able to use each type....
Definition: ShaderType.hh:34
@ ST_COUNT
Total number of shader types.
Definition: ShaderType.hh:52
