Visual.hh
virtual unsigned int GeometryCount() const =0
STL class.
virtual void SetUserData(const std::string &_key, Variant _value)=0
Store any custom data associated with this visual.
virtual void SetMaterial(const std::string &_name, bool _unique=true)=0
Set the material for all attached visuals and geometries. The specified material will be retrieved fr...
virtual GeometryPtr RemoveGeometry(GeometryPtr _geometry)=0
Remove the given geometry from this visual. If the given node is not a child of this visual,...
virtual GeometryPtr RemoveGeometryByIndex(unsigned int _index)=0
Remove the geometry at the given index from this visual. If the specified node is not attached this v...
virtual Variant UserData(const std::string &_key) const =0
Get custom data stored in this visual.
virtual GeometryPtr GeometryByIndex(unsigned int _index) const =0
virtual void AddGeometry(GeometryPtr _geometry)=0
virtual bool HasGeometry(ConstGeometryPtr _geometry) const =0
Definition: Visual.hh:36
virtual MaterialPtr Material()=0
virtual void SetVisible(bool _visible)=0
std::variant< int, float, double, std::string > Variant
Definition: Visual.hh:31
virtual void RemoveGeometries()=0
virtual void SetGeometryMaterial(MaterialPtr _material, bool _unique=true)=0
virtual void SetChildMaterial(MaterialPtr _material, bool _unique=true)=0
