Bounding Box camera
This example shows how to use the bounding box camera.
Clone the source code, create a build directory and use cmake
and make
to compile the code:
cd gz-rendering/examples/boundingbox_camera
./boundingbox_camera
[Msg] Loading plugin [ignition-rendering-ogre2]
S - Save image & its boxes
By default, you'll see 3D boxes:
There are 2 other types of boxes:
- 2D visible: box around the visible parts of an object.
- 2D full: box around the object, including parts that aren't visible to the camera.
Compare the two 2D box types as followS:
./boundingbox_camera 2D_visible
./boundingbox_camera 2D_full
Note how the bounding box for the right sphere is larger for the 2D full box.
