BaseDepthCamera.hh
17 #ifndef IGNITION_RENDERING_BASE_BASEDEPTHCAMERA_HH_
18 #define IGNITION_RENDERING_BASE_BASEDEPTHCAMERA_HH_
20 #include <string>
21
22 #include <ignition/common/Event.hh>
23
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  template <class T>
33  class BaseDepthCamera :
34  public virtual DepthCamera,
35  public virtual BaseCamera<T>,
36  public virtual T
37  {
38  protected: BaseDepthCamera();
39
40  public: virtual ~BaseDepthCamera();
41
42  public: virtual void CreateDepthTexture();
43
44  public: virtual const float *DepthData() const;
45
46  public: virtual ignition::common::ConnectionPtr ConnectNewDepthFrame(
47  std::function<void(const float *, unsigned int, unsigned int,
48  unsigned int, const std::string &)> _subscriber);
49
50  public: virtual ignition::common::ConnectionPtr ConnectNewRGBPointCloud(
51  std::function<void(const float *, unsigned int, unsigned int,
52  unsigned int, const std::string &)> _subscriber);
53  };
54
56  template <class T>
58  {
59  }
60
62  template <class T>
64  {
65  }
66
68  template <class T>
70  {
71  }
72
74  template <class T>
75  const float *BaseDepthCamera<T>::DepthData() const
76  {
77  return nullptr;
78  }
79
81  template <class T>
83  std::function<void(const float *, unsigned int, unsigned int,
84  unsigned int, const std::string &)>)
85  {
86  return nullptr;
87  }
88
90  template <class T>
92  std::function<void(const float *, unsigned int, unsigned int,
93  unsigned int, const std::string &)>)
94  {
95  return nullptr;
96  }
97  }
98  }
99 }
100 #endif
virtual ignition::common::ConnectionPtr ConnectNewRGBPointCloud(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
Definition: BaseDepthCamera.hh:91
STL class.
BaseDepthCamera()
Definition: BaseDepthCamera.hh:57
Definition: BaseDepthCamera.hh:63
virtual const float * DepthData() const
All things needed to get back z buffer for depth data.
Definition: BaseDepthCamera.hh:75
Create a texture which will hold the depth data.
Definition: BaseDepthCamera.hh:69
virtual ignition::common::ConnectionPtr ConnectNewDepthFrame(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
Connect to the new depth image signal.
Definition: BaseDepthCamera.hh:82
