BaseMarker.hh
16 */
17 #ifndef IGNITION_RENDERING_BASEMARKER_HH_
18 #define IGNITION_RENDERING_BASEMARKER_HH_
21
25
26 namespace ignition
27 {
28  namespace rendering
29  {
30  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  template <class T>
33  class BaseMarker :
34  public virtual Marker,
35  public virtual T
36  {
38  protected: BaseMarker();
39
41  public: virtual ~BaseMarker();
42
44  public: virtual void PreRender() override;
45
47  public: virtual void Destroy() override;
48
49  // Documentation inherited
50  public: virtual void SetLifetime(const
51  std::chrono::steady_clock::duration &_lifetime) override;
52
53  // Documentation inherited
54  public: virtual std::chrono::steady_clock::duration Lifetime()
55  const override;
56
57  // Documentation inherited
58  public: virtual void SetType(const MarkerType _markerType) override;
59
60  // Documentation inherited
61  public: virtual MarkerType Type() const override;
62
63  // Documentation inherited
64  public: virtual void SetSize(double _size) override;
65
66  // Documentation inherited
67  public: virtual double Size() const override;
68
69  // Documentation inherited
70  public: virtual void SetLayer(int32_t _layer) override;
71
72  // Documentation inherited
73  public: virtual int32_t Layer() const override;
74
75  // Documentation inherited
76  public: virtual void ClearPoints() override;
77
78  // Documentation inherited
79  public: virtual void AddPoint(double _x,
80  double _y, double _z,
81  const ignition::math::Color &_color) override;
82
83  // Documentation inherited
84  public: virtual void AddPoint(const ignition::math::Vector3d &_pt,
85  const ignition::math::Color &_color) override;
86
87  // Documentation inherited
88  public: virtual void SetPoint(unsigned int _index,
89  const ignition::math::Vector3d &_value) override;
90
93  protected: std::chrono::steady_clock::duration lifetime =
94  std::chrono::steady_clock::duration::zero();
96
98  protected: int32_t layer = 0;
99
101  protected: bool markerDirty = false;
102
104  protected: MarkerType markerType =
106
108  protected: double size = 1.0;
109  };
110
112  // BaseMarker
114  template <class T>
116  {
117  }
118
120  template <class T>
122  {
123  }
124
126  template <class T>
128  const std::chrono::steady_clock::duration &_lifetime)
129  {
130  this->lifetime = _lifetime;
131  this->markerDirty = true;
132  }
133
135  template <class T>
136  std::chrono::steady_clock::duration BaseMarker<T>::Lifetime() const
137  {
138  return this->lifetime;
139  }
140
142  template <class T>
143  void BaseMarker<T>::SetLayer(int32_t _layer)
144  {
145  this->layer = _layer;
146  this->markerDirty = true;
147  }
148
150  template <class T>
151  int32_t BaseMarker<T>::Layer() const
152  {
153  return this->layer;
154  }
155
157  template <class T>
158  void BaseMarker<T>::SetType(const MarkerType _markerType)
159  {
160  this->markerType = _markerType;
161  this->markerDirty = true;
162  }
163
165  template <class T>
167  {
168  return this->markerType;
169  }
170
172  template <class T>
173  void BaseMarker<T>::SetSize(double _size)
174  {
175  this->size = _size;
176  this->markerDirty = true;
177  }
178
180  template <class T>
181  double BaseMarker<T>::Size() const
182  {
183  return this->size;
184  }
185
187  template <class T>
189  {
190  T::PreRender();
191  }
192
194  template <class T>
196  {
197  T::Destroy();
198  }
199
201  template <class T>
203  {
204  // no op
205  }
206
208  template <class T>
210  const ignition::math::Color &)
211  {
212  // no op
213  }
214
216  template <class T>
217  void BaseMarker<T>::AddPoint(double _x, double _y, double _z,
218  const ignition::math::Color &_color)
219  {
220  this->AddPoint(ignition::math::Vector3d(_x, _y, _z), _color);
221  }
222
224  template <class T>
225  void BaseMarker<T>::SetPoint(unsigned int,
226  const ignition::math::Vector3d &)
227  {
228  // no op
229  }
230  }
231  }
232 }
233 #endif
virtual std::chrono::steady_clock::duration Lifetime() const override
Get the lifetime of this Marker.
Definition: BaseMarker.hh:136
A marker geometry class. The marker&#39;s visual appearance is based on the marker type specified...
Definition: Marker.hh:77
virtual void SetPoint(unsigned int _index, const ignition::math::Vector3d &_value) override
Set an existing point&#39;s vector.
Definition: BaseMarker.hh:225
PreRender function.
Definition: BaseMarker.hh:188
Base implementation of a Marker geometry.
Definition: BaseMarker.hh:33
Set size of the marker. Only affects MT_POINTS. e.g. size of rasterized points in pixels...
Definition: BaseMarker.hh:173
MarkerType
Enum for marker types.
Definition: Marker.hh:35
Clear the points of the marker, if applicable.
Definition: BaseMarker.hh:202
Get the render type of this Marker.
Definition: BaseMarker.hh:166
Destroy function.
Definition: BaseMarker.hh:195
Get the size of the marker.
Definition: BaseMarker.hh:181
Definition: BaseMarker.hh:121
BaseMarker()
Definition: BaseMarker.hh:115
virtual void SetLifetime(const std::chrono::steady_clock::duration &_lifetime) override
Set the lifetime of this Marker.
Definition: BaseMarker.hh:127
Set the render type of this Marker.
Definition: BaseMarker.hh:158
Set the layer of this Marker.
Definition: BaseMarker.hh:143
virtual void AddPoint(double _x, double _y, double _z, const ignition::math::Color &_color) override
Add a point with its respective color to the marker.
Definition: BaseMarker.hh:217
Get the layer of this Marker.
Definition: BaseMarker.hh:151
No type.
Definition: Marker.hh:38
