BaseRenderEngine.hh
17 #ifndef IGNITION_RENDERING_BASE_BASERENDERENGINE_HH_
18 #define IGNITION_RENDERING_BASE_BASERENDERENGINE_HH_
20 #include <map>
21 #include <string>
22 #include <vector>
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  //
33  class IGNITION_RENDERING_VISIBLE BaseRenderEngine :
34  public virtual RenderEngine
35  {
36  protected: BaseRenderEngine();
37
38  public: virtual ~BaseRenderEngine();
39
40  // Documentation Inherited.
41  public: virtual bool Load(
42  const std::map<std::string, std::string> &_params = {}) override;
43
44  public: virtual bool Init() override;
45
46  public: virtual bool Fini() override;
47
48  public: virtual bool IsLoaded() const override;
49
50  public: virtual bool IsInitialized() const override;
51
52  public: virtual bool IsEnabled() const override;
53
54  public: virtual unsigned int SceneCount() const override;
55
56  public: virtual bool HasScene(ConstScenePtr _scene) const override;
57
58  public: virtual bool HasSceneId(unsigned int _id) const override;
59
60  public: virtual bool HasSceneName(const std::string &_name) const
61  override;
62
63  public: virtual ScenePtr SceneById(unsigned int _id) const override;
64
65  public: virtual ScenePtr SceneByName(const std::string &_name) const
66  override;
67
68  public: virtual ScenePtr SceneByIndex(unsigned int _index) const override;
69
70  public: virtual void DestroyScene(ScenePtr _scene) override;
71
72  public: virtual void DestroySceneById(unsigned int _id) override;
73
74  public: virtual void DestroySceneByName(const std::string &_name)
75  override;
76
77  public: virtual void DestroySceneByIndex(unsigned int _index) override;
78
79  public: virtual void DestroyScenes() override;
80
81  public: virtual ScenePtr CreateScene(const std::string &_name) override;
82
83  public: virtual ScenePtr CreateScene(unsigned int _id,
84  const std::string &_name) override;
85
86  public: virtual void Destroy() override;
87
88  // Documentation Inherited
89  public: virtual void AddResourcePath(const std::string &_path) override;
90
91  // Documentation Inherited
92  public: virtual void SetHeadless(bool _headless) override;
93
94  // Documentation Inherited
95  public: virtual bool Headless() const override;
96
97  // Documentation Inherited
98  public: virtual RenderPassSystemPtr RenderPassSystem() const override;
99
100  protected: virtual void PrepareScene(ScenePtr _scene);
101
102  protected: virtual unsigned int NextSceneId();
103
106  protected: virtual bool LoadImpl(
107  const std::map<std::string, std::string> &_params) = 0;
108
109  protected: virtual bool InitImpl() = 0;
110
111  protected: virtual ScenePtr CreateSceneImpl(unsigned int _id,
112  const std::string &_name) = 0;
113
114  protected: virtual SceneStorePtr Scenes() const = 0;
115
116  protected: bool loaded = false;
117
118  protected: bool initialized = false;
119
120  protected: bool isHeadless = false;
121
123  protected: std::string winID = "";
124
125  protected: unsigned int nextSceneId;
126
131
135  };
136  }
137  }
138 }
139 #endif
A class for creating and managing render passes.
Definition: RenderPassSystem.hh:56
std::vector< std::string > resourcePaths
a list of paths that render engines use to locate their resources
Definition: BaseRenderEngine.hh:130
RenderPassSystemPtr renderPassSystem
Render pass system for this render engine.
Definition: BaseRenderEngine.hh:133
STL class.
STL class.
Definition: BaseRenderEngine.hh:33
Definition: BaseRenderEngine.hh:125
Definition: RenderEngine.hh:36
