BaseThermalCamera.hh
17 #ifndef IGNITION_RENDERING_BASE_BASETHERMALCAMERA_HH_
18 #define IGNITION_RENDERING_BASE_BASETHERMALCAMERA_HH_
20 #include <string>
21
24
25 namespace ignition
26 {
27  namespace rendering
28  {
29  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
30  //
32  template <class T>
34  public virtual ThermalCamera,
35  public virtual BaseCamera<T>,
36  public virtual T
37  {
39  protected: BaseThermalCamera();
40
42  public: virtual ~BaseThermalCamera();
43
44  // Documentation inherited.
45  public: virtual void SetAmbientTemperature(float _ambient) override;
46
47  // Documentation inherited.
48  public: virtual float AmbientTemperature() const override;
49
50  // Documentation inherited.
51  public: virtual void SetAmbientTemperatureRange(float _range) override;
52
53  // Documentation inherited.
54  public: virtual float AmbientTemperatureRange() const override;
55
56  // Documentation inherited.
57  public: virtual void SetMinTemperature(float _min) override;
58
59  // Documentation inherited.
60  public: virtual float MinTemperature() const override;
61
62  // Documentation inherited.
63  public: virtual void SetMaxTemperature(float _max) override;
64
65  // Documentation inherited.
66  public: virtual float MaxTemperature() const override;
67
68  // Documentation inherited.
69  public: virtual void SetLinearResolution(float _max) override;
70
71  // Documentation inherited.
72  public: virtual float LinearResolution() const override;
73
74  // Documentation inherited.
75  public: virtual float HeatSourceTemperatureRange() const override;
76
77  // Documentation inherited.
78  public: virtual void SetHeatSourceTemperatureRange(float _range) override;
79
80  // Documentation inherted.
81  public: virtual ignition::common::ConnectionPtr ConnectNewThermalFrame(
82  std::function<void(const uint16_t *, unsigned int, unsigned int,
83  unsigned int, const std::string &)> _subscriber) override;
84
86  protected: float ambient = 0.0f;
87
89  protected: float ambientRange = 0.0f;
90
92  protected: float minTemp = -ignition::math::INF_F;
93
95  protected: float maxTemp = ignition::math::INF_F;
96
98  protected: float resolution = 0.01f;
99
101  protected: float heatSourceTempRange = 0.0f;
102  };
103
105  template <class T>
107  {
108  }
109
111  template <class T>
113  {
114  }
115
117  template <class T>
119  {
120  this->ambient = _ambient;
121  }
122
124  template <class T>
126  {
127  return this->ambient;
128  }
129
131  template <class T>
133  {
134  this->ambientRange = _range;
135  }
136
138  template <class T>
140  {
141  return this->ambientRange;
142  }
143
145  template <class T>
147  {
148  this->minTemp = _min;
149  }
150
152  template <class T>
154  {
155  return this->minTemp;
156  }
157
159  template <class T>
161  {
162  this->maxTemp = _max;
163  }
164
166  template <class T>
168  {
169  return this->maxTemp;
170  }
171
173  template <class T>
175  {
176  this->resolution = _resolution;
177  }
178
180  template <class T>
182  {
183  return this->resolution;
184  }
185
187  template <class T>
189  {
190  this->heatSourceTempRange = _range;
191  }
192
194  template <class T>
196  {
197  return this->heatSourceTempRange;
198  }
199
201  template <class T>
203  std::function<void(const uint16_t *, unsigned int, unsigned int,
204  unsigned int, const std::string &)>)
205  {
206  return nullptr;
207  }
208  }
209  }
210 }
211 #endif
static const float INF_F
Get the temperature linear resolution.
Definition: BaseThermalCamera.hh:181
Definition: BaseCamera.hh:44
Definition: BaseThermalCamera.hh:112
Thermal camera that produces temperature data. An object&#39;s temperature can be set through the Visual ...
Definition: ThermalCamera.hh:40
Get the range of ambient temperature.
Definition: BaseThermalCamera.hh:139
Set the range of temperature variation for all heat sources. If set, the temperature reading of heat ...
Definition: BaseThermalCamera.hh:188
Set the range of ambient temperature.
Definition: BaseThermalCamera.hh:132
BaseThermalCamera()
Definition: BaseThermalCamera.hh:106
STL class.
Set the minimum temperature the sensor can detect.
Definition: BaseThermalCamera.hh:146
Base implementation of the ThermalCamera class.
Definition: BaseThermalCamera.hh:33
virtual ignition::common::ConnectionPtr ConnectNewThermalFrame(std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect to the new thermal image event.
Definition: BaseThermalCamera.hh:202
Get the maximum temperature the sensor can detect.
Definition: BaseThermalCamera.hh:167
Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin ...
Definition: BaseThermalCamera.hh:174
Set the ambient temperature of the environment.
Definition: BaseThermalCamera.hh:118
Get the range of temperature variation for all heat sources.
Definition: BaseThermalCamera.hh:195
Get the minimum temperature the sensor can detect.
Definition: BaseThermalCamera.hh:153
Set the maximum temperature the sensor can detect.
Definition: BaseThermalCamera.hh:160
Get the ambient temperature of the environment.
Definition: BaseThermalCamera.hh:125
