GpuRays.hh
17 #ifndef IGNITION_RENDERING_GPURAYS_HH_
18 #define IGNITION_RENDERING_GPURAYS_HH_
20 #include <string>
21
22 #include <ignition/common/Event.hh>
23
28
29 namespace ignition
30 {
31  namespace rendering
32  {
33  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
34  //
37  class IGNITION_RENDERING_VISIBLE GpuRays :
38  public virtual Camera
39  {
41  public: typedef std::function<void(const void*, unsigned int,
42  unsigned int, unsigned int, const std::string&)> NewFrameListener;
43
45  public: virtual ~GpuRays() { }
46
49  public: virtual const float *Data() const = 0;
50
52  public: virtual void Copy(float *_data) = 0;
53
56  // false to leave data values as +/-inf when out of camera range
57  public: virtual void SetClamp(const bool _clamp) = 0;
58
61  // false if data values outside of camera range are returned as +/-inf
62  public: virtual bool Clamp() const = 0;
63
78  public: virtual common::ConnectionPtr ConnectNewGpuRaysFrame(
79  std::function<void(const float *_frame, unsigned int _width,
80  unsigned int _height, unsigned int _depth,
81  const std::string &)> _subscriber) = 0;
82
85  public: virtual void SetIsHorizontal(const bool _horizontal) = 0;
86
89  public: virtual bool IsHorizontal() const = 0;
90
93  public: virtual math::Angle VFOV() const = 0;
94
97  public: virtual double RayCountRatio() const = 0;
98
101  public: virtual double RangeCountRatio() const = 0;
102
105  public: virtual void SetRayCountRatio(const double _rayCountRatio) = 0;
106
108  // \return minimal horizontal angle value
109  public: virtual ignition::math::Angle AngleMin() const = 0;
110
112  public: virtual void SetAngleMin(double _angle) = 0;
113
115  // \return maximal horizontal angle value
116  public: virtual ignition::math::Angle AngleMax() const = 0;
117
119  public: virtual void SetAngleMax(double _angle) = 0;
120
122  // \return horizontal quantity of rays
123  public: virtual int RayCount() const = 0;
124
126  public: virtual void SetRayCount(int _samples) = 0;
127
129  // \return horizontal range count
130  public: virtual int RangeCount() const = 0;
131
133  // \return vertical quantity of rays
134  public: virtual int VerticalRayCount() const = 0;
135
137  public: virtual void SetVerticalRayCount(int _samples) = 0;
138
140  // \return Vertical range count
141  public: virtual int VerticalRangeCount() const = 0;
142
144  // \return minimal vertical angle value
145  public: virtual ignition::math::Angle VerticalAngleMin() const = 0;
146
148  public: virtual void SetVerticalAngleMin(const double _angle) = 0;
149
151  // \return maximal vertical angle value
152  public: virtual ignition::math::Angle VerticalAngleMax() const = 0;
153
155  // \return minimal vertical angle value
156  public: virtual void SetVerticalAngleMax(const double _angle) = 0;
157
160  public: virtual unsigned int Channels() const = 0;
161
169  public: virtual void SetHorizontalResolution(double _resolution) = 0;
170
176  public: virtual double HorizontalResolution() const = 0;
177
185  public: virtual void SetVerticalResolution(double _resolution) = 0;
186
192  public: virtual double VerticalResolution() const = 0;
193  };
194  }
195  }
196 }
197 #endif
Generate depth ray data.
Definition: GpuRays.hh:37
STL class.
std::function< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> NewFrameListener
Definition: GpuRays.hh:42
Definition: Camera.hh:49
virtual ~GpuRays()
Definition: GpuRays.hh:45
