Ogre2RenderTypes.hh File Reference
#include <memory>#include "ignition/rendering/config.hh"#include "ignition/rendering/base/BaseRenderTypes.hh"Go to the source code of this file.
Namespaces | |
| ignition | |
| ignition::rendering | |
| Rendering classes and function useful in robot applications. | |
Typedefs | |
| typedef shared_ptr< Ogre2ArrowVisual > | Ogre2ArrowVisualPtr |
| typedef shared_ptr< Ogre2AxisVisual > | Ogre2AxisVisualPtr |
| typedef shared_ptr< Ogre2Camera > | Ogre2CameraPtr |
| typedef shared_ptr< Ogre2Capsule > | Ogre2CapsulePtr |
| typedef shared_ptr< Ogre2COMVisual > | Ogre2COMVisualPtr |
| typedef shared_ptr< Ogre2DepthCamera > | Ogre2DepthCameraPtr |
| typedef shared_ptr< Ogre2DirectionalLight > | Ogre2DirectionalLightPtr |
| typedef shared_ptr< Ogre2Geometry > | Ogre2GeometryPtr |
| typedef BaseGeometryStore< Ogre2Geometry > | Ogre2GeometryStore |
| typedef shared_ptr< Ogre2GeometryStore > | Ogre2GeometryStorePtr |
| typedef shared_ptr< Ogre2GizmoVisual > | Ogre2GizmoVisualPtr |
| typedef shared_ptr< Ogre2GpuRays > | Ogre2GpuRaysPtr |
| typedef shared_ptr< Ogre2Grid > | Ogre2GridPtr |
| typedef shared_ptr< Ogre2Heightmap > | Ogre2HeightmapPtr |
| typedef shared_ptr< Ogre2InertiaVisual > | Ogre2InertiaVisualPtr |
| typedef shared_ptr< Ogre2JointVisual > | Ogre2JointVisualPtr |
| typedef shared_ptr< Ogre2LidarVisual > | Ogre2LidarVisualPtr |
| typedef shared_ptr< Ogre2Light > | Ogre2LightPtr |
| typedef BaseLightStore< Ogre2Light > | Ogre2LightStore |
| typedef shared_ptr< Ogre2LightStore > | Ogre2LightStorePtr |
| typedef shared_ptr< Ogre2LightVisual > | Ogre2LightVisualPtr |
| typedef shared_ptr< Ogre2Marker > | Ogre2MarkerPtr |
| typedef BaseMaterialMap< Ogre2Material > | Ogre2MaterialMap |
| typedef shared_ptr< Ogre2MaterialMap > | Ogre2MaterialMapPtr |
| typedef shared_ptr< Ogre2Material > | Ogre2MaterialPtr |
| typedef shared_ptr< Ogre2MeshFactory > | Ogre2MeshFactoryPtr |
| typedef shared_ptr< Ogre2Mesh > | Ogre2MeshPtr |
| typedef shared_ptr< Ogre2Node > | Ogre2NodePtr |
| typedef BaseNodeStore< Ogre2Node > | Ogre2NodeStore |
| typedef shared_ptr< Ogre2NodeStore > | Ogre2NodeStorePtr |
| typedef shared_ptr< Ogre2ObjectInterface > | Ogre2ObjectInterfacePtr |
| typedef shared_ptr< Ogre2Object > | Ogre2ObjectPtr |
| typedef shared_ptr< Ogre2ParticleEmitter > | Ogre2ParticleEmitterPtr |
| typedef shared_ptr< Ogre2PointLight > | Ogre2PointLightPtr |
| typedef shared_ptr< Ogre2RayQuery > | Ogre2RayQueryPtr |
| typedef shared_ptr< Ogre2RenderEngine > | Ogre2RenderEnginePtr |
| typedef shared_ptr< Ogre2RenderTargetMaterial > | Ogre2RenderTargetMaterialPtr |
| typedef shared_ptr< Ogre2RenderTarget > | Ogre2RenderTargetPtr |
| typedef shared_ptr< Ogre2RenderTexture > | Ogre2RenderTexturePtr |
| typedef shared_ptr< Ogre2RenderWindow > | Ogre2RenderWindowPtr |
| typedef shared_ptr< Ogre2Scene > | Ogre2ScenePtr |
| typedef BaseSceneStore< Ogre2Scene > | Ogre2SceneStore |
| typedef shared_ptr< Ogre2SceneStore > | Ogre2SceneStorePtr |
| typedef shared_ptr< Ogre2SegmentationCamera > | Ogre2SegmentationCameraPtr |
| typedef shared_ptr< Ogre2Sensor > | Ogre2SensorPtr |
| typedef BaseSensorStore< Ogre2Sensor > | Ogre2SensorStore |
| typedef shared_ptr< Ogre2SensorStore > | Ogre2SensorStorePtr |
| typedef shared_ptr< Ogre2SpotLight > | Ogre2SpotLightPtr |
| typedef shared_ptr< Ogre2SubMesh > | Ogre2SubMeshPtr |
| typedef BaseSubMeshStore< Ogre2SubMesh > | Ogre2SubMeshStore |
| typedef shared_ptr< Ogre2SubMeshStore > | Ogre2SubMeshStorePtr |
| typedef shared_ptr< Ogre2ThermalCamera > | Ogre2ThermalCameraPtr |
| typedef shared_ptr< Ogre2Visual > | Ogre2VisualPtr |
| typedef BaseVisualStore< Ogre2Visual > | Ogre2VisualStore |
| typedef shared_ptr< Ogre2VisualStore > | Ogre2VisualStorePtr |
| typedef shared_ptr< Ogre2WireBox > | Ogre2WireBoxPtr |
