OgreRTShaderSystem.hh
17 #ifndef IGNITION_RENDERING_OGRE_OGRERTSHADERSYSTEM_HH_
18 #define IGNITION_RENDERING_OGRE_OGRERTSHADERSYSTEM_HH_
20 #include <memory>
21 #include <string>
22
26 #include "ignition/rendering/ogre/Export.hh"
27
28 namespace ignition
29 {
30  namespace rendering
31  {
32  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  //
34  // forward declaration
35  class OgreRTShaderSystemPrivate;
36
39
45  class IGNITION_RENDERING_OGRE_VISIBLE OgreRTShaderSystem :
46  public common::SingletonT<OgreRTShaderSystem>
47  {
50  public: enum LightingModel
51  {
61  SSLM_NormalMapLightingObjectSpace
62  };
63
65  private: OgreRTShaderSystem();
66
68  private: virtual ~OgreRTShaderSystem();
69
73  public: bool Init();
74
76  public: void Fini();
77
79  public: void Clear();
80
83  public: void AddScene(OgreScenePtr _scene);
84
87  public: void RemoveScene(OgreScenePtr _scene);
88
91  public: void RemoveScene(const std::string &_scene);
92
94  public: void UpdateShaders();
95
98  public: void AttachEntity(OgreSubMesh *_vis);
99
102  public: void DetachEntity(OgreSubMesh *_vis);
103
107  public: static void AttachViewport(Ogre::Viewport *_viewport,
108  OgreScenePtr _scene);
109
113  public: static void DetachViewport(Ogre::Viewport *_viewport,
114  OgreScenePtr _scene);
115
118  public: void SetPerPixelLighting(bool _set);
119
122  public: void RemoveShaders(OgreSubMesh *_subMesh);
123
126  public: void GenerateShaders(OgreSubMesh *_subMesh);
127
130  public: void ApplyShadows(OgreScenePtr _scene);
131
134  public: void RemoveShadows(OgreScenePtr _scene);
135
138  public: Ogre::PSSMShadowCameraSetup *PSSMShadowCameraSetup() const;
139
144  private: bool Paths(std::string &_coreLibsPath,
145  std::string &_cachePath);
146
151  public: bool SetShadowTextureSize(const unsigned int _size);
152
155  public: unsigned int ShadowTextureSize() const;
156
159  public: bool IsInitialized() const;
160
169  public: void Update();
170
172  private: friend class common::SingletonT<OgreRTShaderSystem>;
173
176  };
178  }
179  }
180 }
181 #endif
Definition: OgreMesh.hh:104
LightingModel
The type of lighting.
Definition: OgreRTShaderSystem.hh:50
STL class.
Per-Vertex lighting: best performance.
Definition: OgreRTShaderSystem.hh:53
Per-Pixel lighting: best look.
Definition: OgreRTShaderSystem.hh:55
Implements Ogre&#39;s Run-Time Shader system.
Definition: OgreRTShaderSystem.hh:45
Normal Map lighting: lighting calculations have been stored in a light map (texture) using tangent sp...
Definition: OgreRTShaderSystem.hh:58
