PixelFormat.hh
17 #ifndef IGNITION_RENDERING_PIXELFORMAT_HH_
18 #define IGNITION_RENDERING_PIXELFORMAT_HH_
20 #include <string>
21 #include "ignition/rendering/config.hh"
22 #include "ignition/rendering/Export.hh"
23
24 namespace ignition
25 {
26  namespace rendering
27  {
29  //
32  enum IGNITION_RENDERING_VISIBLE PixelFormat
33  {
37  PF_L8 = 1,
39  PF_R8G8B8 = 2,
41  PF_B8G8R8 = 3,
50  // Float32 format one channel
52  // Float32 format and RGB
54  // Float32 format and RGB
56  // 16 bit single channel
57  PF_L16 = 11,
61  PF_COUNT = 13
62  };
63
66  class IGNITION_RENDERING_VISIBLE PixelUtil
67  {
70  public: static bool IsValid(PixelFormat _format);
71
77  public: static PixelFormat Sanitize(PixelFormat _format);
78
82  public: static std::string Name(PixelFormat _format);
83
88  public: static unsigned int ChannelCount(PixelFormat _format);
89
94  public: static unsigned int BytesPerChannel(PixelFormat _format);
95
100  public: static unsigned int BytesPerPixel(PixelFormat _format);
101
110  public: static unsigned int MemorySize(PixelFormat _format,
111  unsigned int _width, unsigned int _height);
112
118  public: static PixelFormat Enum(const std::string &_name);
119
121  private: static const char *names[PF_COUNT];
122
124  private: static const unsigned char channelCounts[PF_COUNT];
125
127  private: static const unsigned char channelByteCounts[PF_COUNT];
128  };
129  }
130  }
131 }
132 #endif
< RGBA, 1-byte per channel
Definition: PixelFormat.hh:59
< Bayer GBGR, 1-byte per channel
Definition: PixelFormat.hh:47
< Bayer GRGB, 1-byte per channel
Definition: PixelFormat.hh:49
Definition: PixelFormat.hh:57
Provides supporting functions for PixelFormat enum.
Definition: PixelFormat.hh:66
< RGB, 1-byte per channel
Definition: PixelFormat.hh:39
Definition: PixelFormat.hh:51
< Bayer RGGB, 1-byte per channel
Definition: PixelFormat.hh:43
STL class.
< BGR, 1-byte per channel
Definition: PixelFormat.hh:41
< Grayscale, 1-byte per channel
Definition: PixelFormat.hh:37
PixelFormat
Image pixel format types.
Definition: PixelFormat.hh:32
Definition: PixelFormat.hh:55
< Number of pixel format types
Definition: PixelFormat.hh:61
< Bayer BGGR, 1-byte per channel
Definition: PixelFormat.hh:45
< Unknown or errant type
Definition: PixelFormat.hh:35
Definition: PixelFormat.hh:53
