ThermalCamera.hh
17 #ifndef IGNITION_RENDERING_THERMALCAMERA_HH_
18 #define IGNITION_RENDERING_THERMALCAMERA_HH_
20 #include <string>
22
23 namespace ignition
24 {
25  namespace rendering
26  {
27  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
28  /* \class ThermalCamera ThermalCamera.hh \
29  * ignition/rendering/ThermalCamera.hh
30  */
40  class IGNITION_RENDERING_VISIBLE ThermalCamera :
41  public virtual Camera
42  {
44  public: virtual ~ThermalCamera() { }
45
49  public: virtual void SetAmbientTemperature(float _ambient) = 0;
50
54  public: virtual float AmbientTemperature() const = 0;
55
60  public: virtual void SetAmbientTemperatureRange(float _range) = 0;
61
66  public: virtual float AmbientTemperatureRange() const = 0;
67
71  public: virtual void SetMinTemperature(float _min) = 0;
72
76  public: virtual float MinTemperature() const = 0;
77
81  public: virtual void SetMaxTemperature(float _max) = 0;
82
86  public: virtual float MaxTemperature() const = 0;
87
94  public: virtual void SetLinearResolution(float _resolution) = 0;
95
99  public: virtual float LinearResolution() const = 0;
100
104  public: virtual float HeatSourceTemperatureRange() const = 0;
105
112  public: virtual void SetHeatSourceTemperatureRange(float _range) = 0;
113
118  public: virtual ignition::common::ConnectionPtr ConnectNewThermalFrame(
119  std::function<void(const uint16_t *, unsigned int, unsigned int,
120  unsigned int, const std::string &)> _subscriber) = 0;
121  };
122  }
123  }
124 }
125 #endif
Thermal camera that produces temperature data. An object&#39;s temperature can be set through the Visual ...
Definition: ThermalCamera.hh:40
STL class.
Definition: Camera.hh:49
Definition: ThermalCamera.hh:44
