Ignition Sensors
GpuLidarSensor.hh
16 */
17 #ifndef IGNITION_SENSORS_GPULIDARSENSOR_HH_
18 #define IGNITION_SENSORS_GPULIDARSENSOR_HH_
20 #include <memory>
21 #include <string>
22
23 #include <sdf/sdf.hh>
24
25 #include <ignition/common/SuppressWarning.hh>
26
27 // TODO(louise) Remove these pragmas once ign-rendering is disabling the
28 // warnings
29 #ifdef _WIN32
30 #pragma warning(push)
31 #pragma warning(disable: 4251)
32 #endif
33 #include <ignition/rendering/GpuRays.hh>
34 #ifdef _WIN32
35 #pragma warning(pop)
36 #endif
37
38 #include "ignition/sensors/gpu_lidar/Export.hh"
41
42 namespace ignition
43 {
44  namespace sensors
45  {
46  // Inline bracket to help doxygen filtering.
47  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
48  //
50  class GpuLidarSensorPrivate;
51
61  class IGNITION_SENSORS_GPU_LIDAR_VISIBLE GpuLidarSensor : public Lidar
62  {
64  public: GpuLidarSensor();
65
67  public: virtual ~GpuLidarSensor();
68
72  public: virtual bool Update(
73  const std::chrono::steady_clock::duration &_now) override;
74
77  public: virtual bool Init() override;
78
82  public: virtual bool Load(const sdf::Sensor &_sdf) override;
83
87  public: virtual bool Load(sdf::ElementPtr _sdf) override;
88
90  public: virtual bool CreateLidar() override;
91
94  public: bool IsHorizontal() const;
95
98  public: void SetScene(ignition::rendering::ScenePtr _scene) override;
99
102  public: void RemoveGpuRays(ignition::rendering::ScenePtr _scene);
103
106  public: ignition::rendering::GpuRaysPtr GpuRays() const;
107
114  public: double RayCountRatio() const;
115
118  public: ignition::math::Angle HFOV() const;
119
122  public: ignition::math::Angle VFOV() const;
123
126  public: virtual ignition::common::ConnectionPtr ConnectNewLidarFrame(
127  std::function<void(const float *_scan, unsigned int _width,
128  unsigned int _heighti, unsigned int _channels,
129  const std::string &/*_format*/)> _subscriber) override;
130
131  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
135  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
136  };
137  }
138  }
139 }
140
141 #endif
Lidar Sensor Class.
Definition: Lidar.hh:49
STL class.
GpuLidar Sensor Class.
Definition: GpuLidarSensor.hh:61
Definition: AirPressureSensor.hh:31
