Ignition Sensors
Sensor.hh
2  * Copyright (C) 2017 Open Source Robotics Foundation
16 */
17 #ifndef IGNITION_SENSORS_SENSOR_HH_
18 #define IGNITION_SENSORS_SENSOR_HH_
20 #ifdef _WIN32
21 #pragma warning(push)
22 #pragma warning(disable: 4005)
23 #pragma warning(disable: 4251)
24 #endif
25 #include <ignition/msgs/header.pb.h>
26 #ifdef _WIN32
27 #pragma warning(pop)
28 #endif
29
30 #include <chrono>
31 #include <memory>
32 #include <string>
33
34 #include <ignition/common/SuppressWarning.hh>
35 #include <ignition/math/Pose3.hh>
36 #include <ignition/sensors/config.hh>
37 #include <ignition/sensors/Export.hh>
38 #include <sdf/sdf.hh>
39
40 namespace ignition
41 {
42  namespace sensors
43  {
44  // Inline bracket to help doxygen filtering.
45  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
46  //
49  const SensorId NO_SENSOR = 0;
50
52  class SensorPrivate;
53
59  class IGNITION_SENSORS_VISIBLE Sensor
60  {
62  protected: Sensor();
63
65  public: virtual ~Sensor();
66
70  public: virtual bool Load(const sdf::Sensor &_sdf);
71
75  public: virtual bool Load(sdf::ElementPtr _sdf);
76
81  public: virtual bool Init();
82
96  public: virtual bool Update(
97  const std::chrono::steady_clock::duration &_now) = 0;
98
100  public: std::chrono::steady_clock::duration NextDataUpdateTime() const;
101
115  public: bool Update(
116  const std::chrono::steady_clock::duration &_now, const bool _force);
117
123  public: double UpdateRate() const;
124
129  public: void SetUpdateRate(const double _hz);
130
133  public: ignition::math::Pose3d Pose() const;
134
136  public: void SetPose(const ignition::math::Pose3d &_pose);
137
139  public: virtual void SetParent(const std::string &_parent);
140
143  public: std::string Name() const;
144
147  public: std::string Topic() const;
148
152  public: bool SetTopic(const std::string &_topic);
153
156  public: bool EnableMetrics() const;
157
160  public: void SetEnableMetrics(bool _enableMetrics);
161
164  public: std::string Parent() const;
165
168  public: SensorId Id() const;
169
173  public: sdf::ElementPtr SDF() const;
174
193  public: void AddSequence(ignition::msgs::Header *_msg,
194  const std::string &_seqKey = "default");
195
199  public: void PublishMetrics(
200  const std::chrono::duration<double> &_now);
201
202  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
205  private: std::unique_ptr<SensorPrivate> dataPtr;
206  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
207  };
208  }
209  }
210 }
211
212 #endif
a base sensor class
Definition: Sensor.hh:59
STL class.
Definition: Sensor.hh:49
Definition: AirPressureSensor.hh:31
