BaseRenderPass.hh
17 #ifndef IGNITION_RENDERING_BASE_BASERENDERPASS_HH_
18 #define IGNITION_RENDERING_BASE_BASERENDERPASS_HH_
20 #include <string>
22
23 namespace ignition
24 {
25  namespace rendering
26  {
27  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
28  //
29  /* \class BaseRenderPass BaseRenderPass.hh \
30  * ignition/rendering/base/BaseRenderPass.hh
31  */
33  template <class T>
35  public virtual RenderPass,
36  public T
37  {
39  protected: BaseRenderPass();
40
42  public: virtual ~BaseRenderPass();
43
44  // Documentation inherited
45  public: virtual void SetEnabled(bool _enabled) override;
46
47  // Documentation inherited
48  public: virtual bool IsEnabled() const override;
49
51  protected: bool enabled = true;
52  };
53
55  // BaseRenderPass
57  template <class T>
59  {
60  }
61
63  template <class T>
65  {
66  }
67
69  template <class T>
70  void BaseRenderPass<T>::SetEnabled(bool _enabled)
71  {
72  this->enabled = _enabled;
73  }
74
76  template <class T>
78  {
79  return this->enabled;
80  }
81  }
82  }
83 }
84 #endif
BaseRenderPass()
Definition: BaseRenderPass.hh:58
Definition: BaseRenderPass.hh:70
Definition: BaseRenderPass.hh:77
Definition: BaseRenderPass.hh:64
bool enabled
Flag to indicate if render pass is enabled or not.
Definition: BaseRenderPass.hh:51
A render pass can be added to a camera to affect how the scene is rendered. It can be used to add pos...
Definition: RenderPass.hh:34
Base render pass that can be applied to a render target.
Definition: BaseRenderPass.hh:34
