RenderPass Class Referenceabstract
#include <ignition/rendering/RenderPass.hh>
virtual | ~RenderPass () |
Destructor. More... | |
virtual bool | IsEnabled () const =0 |
Get whether or not the render pass is enabled. More... | |
virtual void | SetEnabled (bool _enabled)=0 |
Set to enable or disable the render pass. More... | |
virtual | ~Object () |
virtual void | Destroy ()=0 |
◆ ~RenderPass()
inlinevirtual |
◆ IsEnabled()
pure virtual |
- Returns
- True if the render pass is enabled, false otherwise.
Implemented in BaseRenderPass< T >.
◆ SetEnabled()
pure virtual |
[in] _enabled True to enable the render pass, false to disable.
Implemented in BaseRenderPass< T >, BaseRenderPass< Ogre2Object >, and BaseRenderPass< OgreObject >.
