Marker.hh
17 #ifndef IGNITION_RENDERING_MARKER_HH_
18 #define IGNITION_RENDERING_MARKER_HH_
20 #include <ignition/common/Time.hh>
21 #include <ignition/math/Color.hh>
22 #include <ignition/math/Vector3.hh>
23 #include "ignition/rendering/config.hh"
27
28 namespace ignition
29 {
30  namespace rendering
31  {
32  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  //
35  enum IGNITION_RENDERING_VISIBLE MarkerType
36  {
38  MT_NONE = 0,
39
41  MT_BOX = 1,
42
45
48
51
53  MT_POINTS = 5,
54
56  MT_SPHERE = 6,
57
59  MT_TEXT = 7,
60
63
66
69  };
70
74  class IGNITION_RENDERING_VISIBLE Marker :
75  public virtual Geometry
76  {
77  protected: Marker();
78
80  public: virtual ~Marker();
81
84  public: virtual void SetLifetime(
85  const std::chrono::steady_clock::duration &_lifetime) = 0;
86
89  public: virtual std::chrono::steady_clock::duration Lifetime() const = 0;
90
93  public: virtual void SetLayer(int32_t _layer) = 0;
94
97  public: virtual int32_t Layer() const = 0;
98
101  public: virtual void SetType(
102  const ignition::rendering::MarkerType _markerType) = 0;
103
106  public: virtual ignition::rendering::MarkerType Type() const = 0;
107
109  public: virtual void ClearPoints() = 0;
110
116  public: virtual void AddPoint(double _x,
117  double _y, double _z,
118  const ignition::math::Color &_color) = 0;
119
123  public: virtual void AddPoint(const ignition::math::Vector3d &_pt,
124  const ignition::math::Color &_color) = 0;
125
129  public: virtual void SetPoint(unsigned int _index,
130  const ignition::math::Vector3d &_value) = 0;
131  };
132  }
133  }
134 }
135
136 #endif
virtual void SetLifetime(const std::chrono::steady_clock::duration &_lifetime)=0
Set the lifetime of this Marker.
@ MT_POINTS
Points primitive.
Definition: Marker.hh:53
@ MT_SPHERE
Sphere geometry.
Definition: Marker.hh:56
@ MT_TRIANGLE_LIST
Triangle list primitive.
Definition: Marker.hh:65
@ MT_TRIANGLE_STRIP
Triangle strip primitive.
Definition: Marker.hh:68
@ MT_NONE
No type.
Definition: Marker.hh:38
@ MT_TEXT
Text geometry.
Definition: Marker.hh:59
@ MT_LINE_STRIP
Line strip primitive.
Definition: Marker.hh:47
virtual void AddPoint(double _x, double _y, double _z, const ignition::math::Color &_color)=0
Add a point with its respective color to the marker.
virtual void SetPoint(unsigned int _index, const ignition::math::Vector3d &_value)=0
Set an existing point's vector.
@ MT_BOX
Box geometry.
Definition: Marker.hh:41
@ MT_LINE_LIST
Line list primitive.
Definition: Marker.hh:50
virtual void SetType(const MarkerType _markerType)=0
Set the render type of this Marker.
@ MT_TRIANGLE_FAN
Triangle fan primitive.
Definition: Marker.hh:62
virtual void ClearPoints()=0
Clear the points of the marker, if applicable.
virtual std::chrono::steady_clock::duration Lifetime() const =0
Get the lifetime of this Marker.
virtual void SetLayer(int32_t _layer)=0
Set the layer of this Marker.
virtual ~Marker()
A marker geometry class. The marker's visual appearance is based on the marker type specified.
Definition: Marker.hh:74
MarkerType
Enum for marker types.
Definition: Marker.hh:35
virtual MarkerType Type() const =0
Get the render type of this Marker.
@ MT_CYLINDER
Cylinder geometry.
Definition: Marker.hh:44
Represents a geometric shape to be rendered.
Definition: Geometry.hh:34
virtual int32_t Layer() const =0
Get the layer of this Marker.
