#include <ignition/rendering/Marker>
virtual ~Marker ()
virtual void AddPoint (const ignition::math::Vector3d &_pt, const ignition::math::Color &_color)=0
virtual void AddPoint (double _x, double _y, double _z, const ignition::math::Color &_color)=0
virtual void ClearPoints ()=0
virtual void SetLayer (int32_t _layer)=0
virtual void SetLifetime (const std::chrono::steady_clock::duration &_lifetime)=0
virtual void SetPoint (unsigned int _index, const ignition::math::Vector3d &_value)=0
virtual void SetType (const MarkerType _markerType)=0
virtual MarkerType Type () const =0
 Marker ()
◆ Marker()
Marker ( )
◆ ~Marker()
virtual ~Marker ( )
◆ AddPoint() [1/2]
virtual void AddPoint ( const ignition::math::Vector3d &  _pt,
Implemented in BaseMarker< T >, BaseMarker< Ogre2Geometry >, BaseMarker< OgreGeometry >, OgreMarker, and Ogre2Marker.
◆ AddPoint() [2/2]
virtual void AddPoint ( double  _x,
double  _y,
double  _z,
[in]_xX coordinate
[in]_yY coordinate
[in]_zZ coordinate
Implemented in BaseMarker< T >, BaseMarker< Ogre2Geometry >, and BaseMarker< OgreGeometry >.
◆ ClearPoints()
virtual void ClearPoints ( )
Implemented in OgreMarker, Ogre2Marker, BaseMarker< T >, BaseMarker< Ogre2Geometry >, and BaseMarker< OgreGeometry >.
◆ Layer()
virtual int32_t Layer ( ) const
The layer of the marker
Implemented in BaseMarker< T >.
◆ Lifetime()
virtual std::chrono::steady_clock::duration Lifetime ( ) const
◆ SetLayer()
virtual void SetLayer ( int32_t  _layer)
◆ SetLifetime()
virtual void SetLifetime ( const std::chrono::steady_clock::duration &  _lifetime)
◆ SetPoint()
◆ SetType()
◆ Type()
The render type of the marker
Implemented in OgreMarker, Ogre2Marker, and BaseMarker< T >.
