#include <ignition/rendering/Storage.hh>
virtual | ~CompositeStore () |
Deconstructor. More... | |
virtual bool | AddStore (TStorePtr _store)=0 |
Add the given store. If the given store already exists, then no work will be done. More... | |
virtual bool | ContainsStore (ConstTStorePtr _store) const =0 |
Determine if given store exists. More... | |
virtual TStorePtr | GetStore (unsigned int _index) const =0 |
Get store at the given index. If no such store exists NULL will be returned. More... | |
virtual unsigned int | GetStoreCount () const =0 |
Get number of Stores. More... | |
virtual TStorePtr | RemoveStore (TStorePtr _store)=0 |
Remove given store. If no such store exists no work will be done and NULL will be returned. More... | |
virtual TStorePtr | RemoveStore (unsigned int _index)=0 |
Remove store at the given index. If no such store exists no work will be done and NULL will be returned. More... | |
virtual | ~Store () |
virtual bool | Add (TPtr _object)=0 |
Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done. More... | |
virtual bool | Contains (ConstTPtr _object) const =0 |
Determine if store contains the given element. More... | |
virtual bool | ContainsId (unsigned int _id) const =0 |
Determine if store contains the element with the given ID. More... | |
virtual bool | ContainsName (const std::string &_name) const =0 |
Determine if store contains the element with the given name. More... | |
virtual void | Destroy (TPtr _object)=0 |
Remove and destroy given element. If the given element does not exists, in this store, then no work will be done. More... | |
virtual void | DestroyAll ()=0 |
Remove and destroy all elements in store. More... | |
virtual void | DestroyById (unsigned int _id)=0 |
Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done. More... | |
virtual void | DestroyByIndex (unsigned int _index)=0 |
Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done. More... | |
virtual void | DestroyByName (const std::string &_name)=0 |
Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done. More... | |
virtual TPtr | GetById (unsigned int _id) const =0 |
Get element with the given ID. More... | |
virtual TPtr | GetByIndex (unsigned int _index) const =0 |
Get element at the given index. More... | |
virtual TPtr | GetByName (const std::string &_name) const =0 |
Get element with the given name. More... | |
virtual TPtr | Remove (TPtr _object)=0 |
Remove given element. If the given element does not exists in this store, then no work will be done. More... | |
virtual void | RemoveAll ()=0 |
Remove all elements from store. More... | |
virtual TPtr | RemoveById (unsigned int _id)=0 |
Remove element with the given ID. If the specified element does not exists in this store, then no work will be done. More... | |
virtual TPtr | RemoveByIndex (unsigned int _index)=0 |
Remove element at the given index. If the specified element does not exists in this store, then no work will be done. More... | |
virtual TPtr | RemoveByName (const std::string &_name)=0 |
Remove element with the given name. If the specified element does not exists in this store, then no work will be done. More... | |
virtual unsigned int | Size () const =0 |
Get number of elements in this store. More... | |
template<class T>
class ignition::rendering::CompositeStore< T >
ignition/rendering/CompositeStore.hh
- Template Parameters
T The storage element type
◆ ~CompositeStore()
inlinevirtual |
Deconstructor.
◆ AddStore()
pure virtual |
[in] _store Store to be added
- Returns
- True if successful
Implemented in BaseCompositeStore< T >, and BaseCompositeStore< Node >.
◆ ContainsStore()
pure virtual |
[in] _store Store in question
- Returns
- True if given store exists
◆ GetStore()
pure virtual |
[in] _index Index of the desired store
- Returns
- The specified store
◆ GetStoreCount()
pure virtual |
- Returns
- The number of Stores
◆ RemoveStore() [1/2]
[in] _store Store to be removed
- Returns
- The removed store
◆ RemoveStore() [2/2]
pure virtual |
[in] _index Index of the store to be removed
- Returns
- The removed store
