Ogre2DynamicRenderable Class Reference
Dynamic renderable class that manages hardware buffers for a dynamic geometry. More...
#include <Ogre2DynamicRenderable.hh>
 Ogre2DynamicRenderable (ScenePtr _scene)
virtual ~Ogre2DynamicRenderable ()
 Virtual destructor. More...
void AddPoint (const double _x, const double _y, const double _z, const ignition::math::Color &_color=ignition::math::Color::White)
 Add a point to the point list. More...
void AddPoint (const ignition::math::Vector3d &_pt, const ignition::math::Color &_color=ignition::math::Color::White)
void Clear ()
 Remove all points from the point list. More...
void Destroy ()
 Destroy the dynamic renderable. More...
 Get the ogre object associated with this dynamic renderable. More...
MarkerType OperationType () const
 Get the render operation type. More...
ignition::math::Vector3d Point (unsigned int _index) const
 Return the position of an existing point in the point list. More...
unsigned int PointCount () const
 Return the total number of points in the point list. More...
void SetColor (unsigned int _index, const ignition::math::Color &_color)
 Change the color of an existing point in the point list. More...
void SetMaterial (MaterialPtr _material, bool _unique=true)
 Set the material for this dynamic renderable. More...
void SetOperationType (MarkerType _opType)
 Set the render operation type. More...
void SetPoint (unsigned int _index, const ignition::math::Vector3d &_value)
 Change the location of an existing point in the point list. More...
void Update ()
 Update the dynamic renderable. More...
◆ Ogre2DynamicRenderable()
Ogre2DynamicRenderable ( ScenePtr  _scene)
[in]_scenePointer to scene
◆ ~Ogre2DynamicRenderable()
virtual ~Ogre2DynamicRenderable ( )
Virtual destructor.
◆ AddPoint() [1/2]
void AddPoint ( const double  _x,
const double  _y,
const double  _z,
const ignition::math::Color &  _color = ignition::math::Color::White
[in]_xX position
[in]_yY position
[in]_zZ position
[in]_colorPoint color
◆ AddPoint() [2/2]
void AddPoint ( const ignition::math::Vector3d &  _pt,
[in]_ptignition::math::Vector3d point
[in]_colorignition::math::Color Point color
◆ Clear()
void Clear ( )
void Destroy ( )
◆ OgreObject()
◆ OperationType()
MarkerType OperationType ( ) const
The render operation type.
◆ Point()
ignition::math::Vector3d Point ( unsigned int  _index) const
[in]_indexGet the point at this index
position of point. A vector of [ignition::math::INF_D, ignition::math::INF_D, ignition::math::INF_D] is returned when then the _index is out of bounds. ignition::math::INF_D==std::numeric_limits<double>::infinity()
◆ PointCount()
Number of points
◆ SetColor()
void SetColor ( unsigned int  _index,
[in]_indexIndex of the point to set
[in]_colorcolor to set the point to
◆ SetMaterial()
bool  _unique = true
◆ SetOperationType()
void SetOperationType ( MarkerType  _opType)
[in]_opTypeThe type of render operation to perform.
◆ SetPoint()
[in]_valuePosition of the point
void Update ( )
