| virtual | ~Ogre2Geometry () |
| | Destructor. More...
| | Determine if this Geometry is attached to a Visual. More...
| virtual Ogre::MovableObject * | OgreObject () const =0 |
| | Get the ogre object representing this geometry. More...
| virtual VisualPtr | Parent () const override |
| | Get the parent Visual. More...
| | Detach this Geometry from its parent Visual. If this Geometry does not have a parent, no work will be done. More...
| | Set the materials of this Geometry. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More...
| virtual void | SetMaterial (MaterialPtr _material, bool _unique=true) override=0 |
| | Set the materials of this Geometry. More...
| virtual | ~Geometry () |
| | Deconstructor. More...
| | Get the material of this geometry. More...
| | Destructor. More...
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
Ogre2.x implementation of the geometry class.
