Ogre2PointLight Class Reference
Ogre 2.x implementation of the point light class. More...
#include <Ogre2Light.hh>
| virtual | ~Ogre2PointLight () |
| Destructor. More... | |
Public Member Functions inherited from BasePointLight< Ogre2Light > | |
| virtual | ~BasePointLight () |
Public Member Functions inherited from PointLight | |
| virtual | ~PointLight () |
| Deconstructor. More... | |
Public Member Functions inherited from Light | |
| virtual | ~Light () |
| virtual | ~Node () |
Public Member Functions inherited from Ogre2Light | |
| virtual | ~Ogre2Light () |
| virtual double | AttenuationConstant () const override |
| Get the attenuation constant value. More... | |
| virtual double | AttenuationLinear () const override |
| Get the attenuation linear value. More... | |
| virtual double | AttenuationQuadratic () const override |
| Get the attenuation quadratic value. More... | |
| virtual double | AttenuationRange () const override |
| Get the attenuation range. More... | |
| virtual bool | CastShadows () const override |
| Determine if this light cast shadows. More... | |
| Destroy the light. More... | |
| virtual math::Color | DiffuseColor () const override |
| Get the diffuse color. More... | |
| virtual Ogre::Light * | Light () const |
| Get a pointer to ogre light. More... | |
| virtual void | SetAttenuationConstant (double _value) override |
| Set the attenuation constant value. More... | |
| virtual void | SetAttenuationLinear (double _value) override |
| Set the attenuation linear value. More... | |
| virtual void | SetAttenuationQuadratic (double _value) override |
| Set the attenuation quadratic value. More... | |
| virtual void | SetAttenuationRange (double _range) override |
| Set the attenuation range. More... | |
| virtual void | SetCastShadows (bool _castShadows) override |
| Specify if this light should cast shadows. More... | |
| virtual void | SetDiffuseColor (const math::Color &_color) override |
| Set the diffuse color. More... | |
| virtual void | SetSpecularColor (const math::Color &_color) override |
| Set the specular color. More... | |
| virtual math::Color | SpecularColor () const override |
| Get the specular color. More... | |
Public Member Functions inherited from BaseLight< Ogre2Node > | |
| virtual | ~BaseLight () |
| virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) |
| virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0) |
Public Member Functions inherited from Ogre2Node | |
| virtual | ~Ogre2Node () |
| Get a pointer to the underlying scene node. More... | |
Public Member Functions inherited from BaseNode< Ogre2Object > | |
| virtual | ~BaseNode () |
| virtual bool | InheritScale () const override=0 |
| virtual math::Vector3d | LocalScale () const override=0 |
| virtual NodePtr | Parent () const override=0 |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2PointLight () | |
| Constructor. More... | |
Protected Member Functions inherited from BasePointLight< Ogre2Light > | |
| BasePointLight () | |
Protected Member Functions inherited from Ogre2Light | |
| Ogre2Light () | |
| Initialize the light. More... | |
Protected Member Functions inherited from BaseLight< Ogre2Node > | |
| BaseLight () | |
| virtual void | Reset () |
Protected Member Functions inherited from Ogre2Node | |
| Ogre2Node () | |
| virtual bool | AttachChild (NodePtr _child) override |
| virtual NodeStorePtr | Children () const override |
| virtual bool | DetachChild (NodePtr _child) override |
| virtual void | Load () override |
| virtual math::Pose3d | RawLocalPose () const override |
| virtual math::Vector3d | RawLocalPosition () const |
| Get the raw local position of the node. More... | |
| virtual math::Quaterniond | RawLocalRotation () const |
| Get the raw local rotation of the node. More... | |
| virtual void | SetLocalScaleImpl (const math::Vector3d &_scale) override |
| Implementation of the SetLocalScale function. More... | |
| virtual void | SetParent (Ogre2NodePtr _parent) |
| Set the parent node. More... | |
| virtual void | SetRawLocalPose (const math::Pose3d &_Pose3d) override |
| virtual void | SetRawLocalPosition (const math::Vector3d &_position) |
| Set the raw local position of the node. More... | |
| virtual void | SetRawLocalRotation (const math::Quaterniond &_rotation) |
| Set the raw local rotation of the node. More... | |
Protected Member Functions inherited from BaseNode< Ogre2Object > | |
| BaseNode () | |
| virtual NodeStorePtr | Children () const=0 |
| virtual void | PreRenderChildren () |
| virtual math::Pose3d | RawLocalPose () const=0 |
| Ogre2Object () | |
| BaseObject () | |
Protected Attributes inherited from Ogre2Light | |
| double | attenConstant = 1.0 |
| Attenuation constant value. More... | |
| double | attenLinear = 0.0 |
| Attenuation linear factor. More... | |
| double | attenQuadratic = 0.0 |
| Attenuation quadratic factor. More... | |
| double | attenRange = 100.0 |
| Attenuation range. More... | |
| Ogre::Light * | ogreLight = nullptr |
| Pointer to ogre light. More... | |
| Ogre::Light::LightTypes | ogreLightType |
| Light type. More... | |
Protected Attributes inherited from Ogre2Node | |
| Ogre2NodeStorePtr | children |
| A list of child nodes. More... | |
| Ogre::SceneNode * | ogreNode = nullptr |
| The underlying ogre scene node. More... | |
| Ogre2NodePtr | parent |
| Pointer to the parent ogre node. More... | |
Protected Attributes inherited from BaseNode< Ogre2Object > | |
| math::Vector3d | origin |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2PointLight()
protected |
◆ ~Ogre2PointLight()
virtual |
