| ignition::AddChild(NodePtr _child)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::AddChild(NodePtr _child) override | BaseNode< Ogre2Object > | virtual |
| AttachChild(NodePtr _child) override | Ogre2Node | protectedvirtual |
| BaseNode() | BaseNode< Ogre2Object > | protected |
| BaseObject() | BaseObject | protected |
| BaseSensor() | BaseSensor< Ogre2Node > | protected |
| ignition::ChildById(unsigned int _id) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::ChildById(unsigned int _id) const override | BaseNode< Ogre2Object > | virtual |
| ignition::ChildByIndex(unsigned int _index) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::ChildByIndex(unsigned int _index) const override | BaseNode< Ogre2Object > | virtual |
| ignition::ChildByName(const std::string &_name) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::ChildByName(const std::string &_name) const override | BaseNode< Ogre2Object > | virtual |
| ignition::ChildCount() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::ChildCount() const override | BaseNode< Ogre2Object > | virtual |
| children | Ogre2Node | protected |
| Children() const override | Ogre2Node | protectedvirtual |
| BaseNode< Ogre2Object >::Children() const=0 | BaseNode< Ogre2Object > | protectedpure virtual |
| ignition::Destroy()=0 | Object | pure virtual |
| ignition::rendering::Ogre2Node::Destroy() override | Ogre2Node | virtual |
| DetachChild(NodePtr _child) override | Ogre2Node | protectedvirtual |
| ignition::HasChild(ConstNodePtr _child) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::HasChild(ConstNodePtr _child) const override | BaseNode< Ogre2Object > | virtual |
| ignition::HasChildId(unsigned int _id) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::HasChildId(unsigned int _id) const override | BaseNode< Ogre2Object > | virtual |
| ignition::HasChildName(const std::string &_name) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::HasChildName(const std::string &_name) const override | BaseNode< Ogre2Object > | virtual |
| ignition::HasParent() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::HasParent() const override | Ogre2Node | virtual |
| id | BaseObject | protected |
| ignition::Id() const =0 | Object | pure virtual |
| ignition::rendering::Ogre2Node::ignition::rendering::Ogre2Object::Id() const override | BaseObject | virtual |
| ignition::InheritScale() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::InheritScale() const override | Ogre2Node | virtual |
| BaseNode< Ogre2Object >::InheritScale() const override=0 | BaseNode< Ogre2Object > | pure virtual |
| Init() override | Ogre2Node | protectedvirtual |
| Load() override | Ogre2Node | protectedvirtual |
| ignition::LocalPose() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::LocalPose() const override | BaseNode< Ogre2Object > | virtual |
| ignition::LocalPosition() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::LocalPosition() const override | BaseNode< Ogre2Object > | virtual |
| ignition::LocalRotation() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::LocalRotation() const override | BaseNode< Ogre2Object > | virtual |
| ignition::LocalScale() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::LocalScale() const override | Ogre2Node | virtual |
| BaseNode< Ogre2Object >::LocalScale() const override=0 | BaseNode< Ogre2Object > | pure virtual |
| name | BaseObject | protected |
| ignition::Name() const =0 | Object | pure virtual |
| ignition::rendering::Ogre2Node::ignition::rendering::Ogre2Object::Name() const override | BaseObject | virtual |
| Node() const | Ogre2Node | virtual |
| Ogre2Node() | Ogre2Node | protected |
| Ogre2Object() | Ogre2Object | protected |
| Ogre2Sensor() | Ogre2Sensor | protected |
| ogreNode | Ogre2Node | protected |
| origin | BaseNode< Ogre2Object > | protected |
| ignition::Origin() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::Origin() const override | BaseNode< Ogre2Object > | virtual |
| ignition::Parent() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::Parent() const override | Ogre2Node | virtual |
| BaseNode< Ogre2Object >::Parent() const override=0 | BaseNode< Ogre2Object > | pure virtual |
| parent | Ogre2Node | protected |
| ignition::PostRender()=0 | Object | pure virtual |
| ignition::rendering::Ogre2Node::ignition::rendering::Ogre2Object::PostRender() override | BaseObject | virtual |
| ignition::PreRender()=0 | Object | pure virtual |
| ignition::rendering::Ogre2Node::PreRender() override | BaseNode< Ogre2Object > | virtual |
| PreRenderChildren() | BaseNode< Ogre2Object > | protectedvirtual |
| RawLocalPose() const override | Ogre2Node | protectedvirtual |
| BaseNode< Ogre2Object >::RawLocalPose() const=0 | BaseNode< Ogre2Object > | protectedpure virtual |
| RawLocalPosition() const | Ogre2Node | protectedvirtual |
| RawLocalRotation() const | Ogre2Node | protectedvirtual |
| ignition::RemoveChild(NodePtr _child)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::RemoveChild(NodePtr _child) override | BaseNode< Ogre2Object > | virtual |
| ignition::RemoveChildById(unsigned int _id)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::RemoveChildById(unsigned int _id) override | BaseNode< Ogre2Object > | virtual |
| ignition::RemoveChildByIndex(unsigned int _index)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::RemoveChildByIndex(unsigned int _index) override | BaseNode< Ogre2Object > | virtual |
| ignition::RemoveChildByName(const std::string &_name)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::RemoveChildByName(const std::string &_name) override | BaseNode< Ogre2Object > | virtual |
| ignition::RemoveChildren()=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::RemoveChildren() override | BaseNode< Ogre2Object > | virtual |
| ignition::RemoveParent()=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::RemoveParent() override | BaseNode< Ogre2Object > | virtual |
| ignition::Scale(double _scale)=0 | Node | pure virtual |
| ignition::Scale(double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::Scale(const math::Vector3d &_scale)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::Scale(double _scale) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::Scale(double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::Scale(const math::Vector3d &_scale) override | BaseNode< Ogre2Object > | virtual |
| scene | Ogre2Object | protected |
| ignition::Scene() const =0 | Object | pure virtual |
| ignition::rendering::Ogre2Node::ignition::rendering::Ogre2Object::Scene() const override | Ogre2Object | virtual |
| ignition::SetInheritScale(bool _inherit)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetInheritScale(bool _inherit) override | Ogre2Node | virtual |
| ignition::SetLocalPose(const math::Pose3d &_pose)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetLocalPose(const math::Pose3d &_pose) override | BaseNode< Ogre2Object > | virtual |
| ignition::SetLocalPosition(double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetLocalPosition(const math::Vector3d &_position)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetLocalPosition(double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetLocalPosition(const math::Vector3d &_position) override | BaseNode< Ogre2Object > | virtual |
| ignition::SetLocalRotation(double _r, double _p, double _y)=0 | Node | pure virtual |
| ignition::SetLocalRotation(double _w, double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetLocalRotation(const math::Quaterniond &_rotation)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetLocalRotation(double _r, double _p, double _y) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetLocalRotation(double _w, double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetLocalRotation(const math::Quaterniond &_rotation) override | BaseNode< Ogre2Object > | virtual |
| ignition::SetLocalScale(double _scale)=0 | Node | pure virtual |
| ignition::SetLocalScale(double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetLocalScale(const math::Vector3d &_scale)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetLocalScale(double _scale) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetLocalScale(double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetLocalScale(const math::Vector3d &_scale) override | BaseNode< Ogre2Object > | virtual |
| SetLocalScaleImpl(const math::Vector3d &_scale) override | Ogre2Node | protectedvirtual |
| ignition::SetOrigin(double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetOrigin(const math::Vector3d &_origin)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetOrigin(double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetOrigin(const math::Vector3d &_origin) override | BaseNode< Ogre2Object > | virtual |
| SetParent(Ogre2NodePtr _parent) | Ogre2Node | protectedvirtual |
| SetRawLocalPose(const math::Pose3d &_Pose3d) override | Ogre2Node | protectedvirtual |
| SetRawLocalPosition(const math::Vector3d &_position) | Ogre2Node | protectedvirtual |
| SetRawLocalRotation(const math::Quaterniond &_rotation) | Ogre2Node | protectedvirtual |
| ignition::SetWorldPose(const math::Pose3d &_pose)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetWorldPose(const math::Pose3d &_pose) override | BaseNode< Ogre2Object > | virtual |
| ignition::SetWorldPosition(double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetWorldPosition(const math::Vector3d &_position)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetWorldPosition(double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetWorldPosition(const math::Vector3d &_position) override | BaseNode< Ogre2Object > | virtual |
| ignition::SetWorldRotation(double _r, double _p, double _y)=0 | Node | pure virtual |
| ignition::SetWorldRotation(double _w, double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetWorldRotation(const math::Quaterniond &_rotation)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetWorldRotation(double _r, double _p, double _y) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetWorldRotation(double _w, double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetWorldRotation(const math::Quaterniond &_rotation) override | BaseNode< Ogre2Object > | virtual |
| ignition::SetWorldScale(double _scale)=0 | Node | pure virtual |
| ignition::SetWorldScale(double _x, double _y, double _z)=0 | Node | pure virtual |
| ignition::SetWorldScale(const math::Vector3d &_scale)=0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::SetWorldScale(double _scale) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetWorldScale(double _x, double _y, double _z) override | BaseNode< Ogre2Object > | virtual |
| ignition::rendering::Ogre2Node::SetWorldScale(const math::Vector3d &_scale) override | BaseNode< Ogre2Object > | virtual |
| ignition::WorldPose() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::WorldPose() const override | BaseNode< Ogre2Object > | virtual |
| ignition::WorldPosition() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::WorldPosition() const override | BaseNode< Ogre2Object > | virtual |
| ignition::WorldRotation() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::WorldRotation() const override | BaseNode< Ogre2Object > | virtual |
| ignition::WorldScale() const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::WorldScale() const override | BaseNode< Ogre2Object > | virtual |
| ignition::WorldToLocal(const math::Pose3d &_pose) const =0 | Node | pure virtual |
| ignition::rendering::Ogre2Node::WorldToLocal(const math::Pose3d &_pose) const override | BaseNode< Ogre2Object > | virtual |
| ~BaseNode() | BaseNode< Ogre2Object > | virtual |
| ~BaseObject() | BaseObject | virtual |
| ~BaseSensor() | BaseSensor< Ogre2Node > | virtual |
| ~Node() | Node | inlinevirtual |
| ~Object() | Object | inlinevirtual |
| ~Ogre2Node() | Ogre2Node | virtual |
| ~Ogre2Object() | Ogre2Object | virtual |
| ~Ogre2Sensor() | Ogre2Sensor | virtual |
| ~Sensor() | Sensor | inlinevirtual |
