Ogre2Sensor Class Reference
Ogre2.x implementation of the sensor classs. More...
#include <Ogre2Sensor.hh>
| virtual | ~Ogre2Sensor () |
| Destructor. More... | |
Public Member Functions inherited from BaseSensor< Ogre2Node > | |
| virtual | ~BaseSensor () |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
| Deconstructor. More... | |
Public Member Functions inherited from Ogre2Node | |
| virtual | ~Ogre2Node () |
| Get a pointer to the underlying scene node. More... | |
Public Member Functions inherited from BaseNode< Ogre2Object > | |
| virtual | ~BaseNode () |
| virtual bool | InheritScale () const override=0 |
| virtual math::Vector3d | LocalScale () const override=0 |
| virtual NodePtr | Parent () const override=0 |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2Sensor () | |
| Constructor. More... | |
Protected Member Functions inherited from BaseSensor< Ogre2Node > | |
| BaseSensor () | |
Protected Member Functions inherited from Ogre2Node | |
| Ogre2Node () | |
| virtual bool | AttachChild (NodePtr _child) override |
| virtual NodeStorePtr | Children () const override |
| virtual bool | DetachChild (NodePtr _child) override |
| virtual void | Load () override |
| virtual math::Pose3d | RawLocalPose () const override |
| virtual math::Vector3d | RawLocalPosition () const |
| Get the raw local position of the node. More... | |
| virtual math::Quaterniond | RawLocalRotation () const |
| Get the raw local rotation of the node. More... | |
| virtual void | SetLocalScaleImpl (const math::Vector3d &_scale) override |
| Implementation of the SetLocalScale function. More... | |
| virtual void | SetParent (Ogre2NodePtr _parent) |
| Set the parent node. More... | |
| virtual void | SetRawLocalPose (const math::Pose3d &_Pose3d) override |
| virtual void | SetRawLocalPosition (const math::Vector3d &_position) |
| Set the raw local position of the node. More... | |
| virtual void | SetRawLocalRotation (const math::Quaterniond &_rotation) |
| Set the raw local rotation of the node. More... | |
Protected Member Functions inherited from BaseNode< Ogre2Object > | |
| BaseNode () | |
| virtual NodeStorePtr | Children () const=0 |
| virtual void | PreRenderChildren () |
| virtual math::Pose3d | RawLocalPose () const=0 |
| Ogre2Object () | |
| BaseObject () | |
Protected Attributes inherited from Ogre2Node | |
| Ogre2NodeStorePtr | children |
| A list of child nodes. More... | |
| Ogre::SceneNode * | ogreNode = nullptr |
| The underlying ogre scene node. More... | |
| Ogre2NodePtr | parent |
| Pointer to the parent ogre node. More... | |
Protected Attributes inherited from BaseNode< Ogre2Object > | |
| math::Vector3d | origin |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2Sensor()
protected |
◆ ~Ogre2Sensor()
virtual |
