#include <OgreCamera.hh>
virtual ~OgreCamera ()
virtual math::Color BackgroundColor () const
double FarClip () const
 Get the far clip distance. More...
double NearClip () const
 Get the near clip distance. More...
virtual void SetBackgroundColor (const math::Color &_color)
void SetVFOV (double cameraVFOV) const
virtual ~BaseCamera ()
virtual ~Camera ()
 Sensor. More...
virtual ~OgreSensor ()
virtual ~BaseSensor ()
virtual ~OgreNode ()
 OgreCamera ()
virtual void SetSelectionBuffer ()
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
math::Color backgroundColor
OgreRenderTargetPtr renderTexture
OgreSelectionBuffer * selectionBuffer = nullptr
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCamera()
OgreCamera ( )
◆ ~OgreCamera()
virtual ~OgreCamera ( )
◆ AntiAliasing()
Implements Camera.
◆ AspectRatio()
The camera's aspect ratio
Implements Camera.
◆ BackgroundColor()
◆ CreateRenderTexture()
◆ CreateRenderWindow()
Reimplemented from OgreNode.
◆ FarClip()
double FarClip ( ) const
Far clip distance
◆ NearClip()
double NearClip ( ) const
Near clip distance
◆ ProjectionMatrix()
Camera projection matrix
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
Implements Camera.
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetBackgroundColor()
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetVFOV()
void SetVFOV ( double  cameraVFOV) const
◆ ViewMatrix()
Camera view matrix
Implements Camera.
◆ VisualAt()
virtual VisualPtr VisualAt ( const ignition::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
OgreSelectionBuffer* selectionBuffer = nullptr
