| virtual | ~OgreGpuRays () |
| | Destructor. More...
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)> _subscriber) override |
| virtual void | Copy (float *_data) override |
| | Copy to the specified memory direction the gpu rays data. More...
| virtual void | CreateRenderTexture () |
| | Create dummy render texture. Needed to satisfy inheritance. More...
| virtual const float * | Data () const override |
| | All things needed to get back z buffer for gpu rays data. More...
| virtual void | notifyRenderSingleObject (Ogre::Renderable *_rend, const Ogre::Pass *_p, const Ogre::AutoParamDataSource *_s, const Ogre::LightList *_ll, bool _supp) override |
| | Preforms any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| virtual RenderTargetPtr | RenderTarget () const override |
| virtual | ~BaseGpuRays () |
| | Destructor. More...
| virtual ignition::math::Angle | AngleMax () const override |
| | Get maximal horizontal angle value. More...
| virtual ignition::math::Angle | AngleMin () const override |
| | Get minimal horizontal angle value. More...
| virtual unsigned int | Channels () const override |
| | Get the number of channels used to store the ray data. More...
| virtual bool | Clamp () const override |
| | Get behaviour for data values outside of camera range. More...
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber) override |
| virtual bool | IsHorizontal () const override |
| | Gets if sensor is horizontal. More...
| virtual int | RangeCount () const override |
| | Get hoizontal range count, i.e. ray count * horz resolution. More...
| virtual double | RangeCountRatio () const override |
| | Get the ray count ratio (equivalent to aspect ratio) More...
| virtual int | RayCount () const override |
| | Get horizontal quantity of rays. More...
| virtual double | RayCountRatio () const override |
| virtual RenderTargetPtr | RenderTarget () const override=0 |
| | Pointer to the render target. More...
| virtual void | SetAngleMax (double _angle) override |
| | Set maximal horizontal angle value. More...
| virtual void | SetAngleMin (double _angle) override |
| | Set minimal horizontal angle value. More...
| virtual void | SetClamp (bool _enable) override |
| | Configure behaviour for data values outside of camera range. More...
| virtual void | SetIsHorizontal (const bool _horizontal) override |
| | Set sensor horizontal or vertical. More...
| virtual void | SetRayCount (int _samples) override |
| | Set horizontal quantity of rays. More...
| virtual void | SetRayCountRatio (const double _rayCountRatio) override |
| | Sets the ray count ratio (equivalent to aspect ratio) More...
| virtual void | SetVerticalAngleMax (const double _angle) override |
| | Set maximal vertical angle value. More...
| virtual void | SetVerticalAngleMin (const double _angle) override |
| | Set minimal vertical angle value. More...
| virtual void | SetVerticalRayCount (int _samples) override |
| | Set vertical quantity of rays. More...
| virtual void | SetVFOV (const math::Angle &_vfov) |
| | Set the vertical fov. More...
| virtual ignition::math::Angle | VerticalAngleMax () const override |
| | Get maximal vertical angle value. More...
| virtual ignition::math::Angle | VerticalAngleMin () const override |
| | Get minimal vertical angle value. More...
| virtual int | VerticalRangeCount () const override |
| | Get vertical range count, i.e. ray count * vert resolution. More...
| virtual int | VerticalRayCount () const override |
| | Get vertical quantity of rays. More...
| virtual math::Angle | VFOV () const override |
| | Get the vertical field-of-view. More...
| virtual | ~GpuRays () |
| | Destructor. More...
| virtual ignition::math::Angle | AngleMax () const =0 |
| virtual ignition::math::Angle | AngleMin () const =0 |
| virtual unsigned int | Channels () const =0 |
| virtual bool | Clamp () const =0 |
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &)> _subscriber)=0 |
| | Connect to a gpu rays frame signal. More...
| virtual bool | IsHorizontal () const =0 |
| virtual int | RangeCount () const =0 |
| virtual double | RangeCountRatio () const =0 |
| virtual int | RayCount () const =0 |
| virtual double | RayCountRatio () const =0 |
| virtual ignition::math::Angle | VerticalAngleMax () const =0 |
| virtual ignition::math::Angle | VerticalAngleMin () const =0 |
| virtual int | VerticalRangeCount () const =0 |
| virtual int | VerticalRayCount () const =0 |
| virtual math::Angle | VFOV () const =0 |
| virtual | ~Camera () |
| | Deconstructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| virtual | ~BaseCamera () |
| virtual VisualPtr | VisualAt (const ignition::math::Vector2i &_mousePos) override |
| virtual | ~OgreSensor () |
| virtual | ~BaseSensor () |
| virtual | ~OgreNode () |
| virtual | ~BaseNode () |
| virtual bool | InheritScale () const override=0 |
| virtual math::Vector3d | LocalScale () const override=0 |
| virtual NodePtr | Parent () const override=0 |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
