OgreMaterialSwitcher Class Reference
Helper class to assign unique colors to renderables. More...
#include <OgreMaterialSwitcher.hh>
 OgreMaterialSwitcher ()
 ~OgreMaterialSwitcher ()
std::string EntityName (const ignition::math::Color &_color) const
 Get the entity with a specific color. More...
virtual Ogre::Technique * handleSchemeNotFound (uint16_t _schemeIndex, const Ogre::String &_schemeName, Ogre::Material *_originalMaterial, uint16_t _lodIndex, const Ogre::Renderable *_rend)
 Ogre callback that assigns colors to new renderables when the requested scheme is not found. More...
virtual void postRenderTargetUpdate (const Ogre::RenderTargetEvent &_evt)
 Ogre's post render update callback. More...
virtual void preRenderTargetUpdate (const Ogre::RenderTargetEvent &_evt)
 Ogre's pre render update callback. More...
void Reset ()
 Reset the color value incrementor. More...
◆ OgreMaterialSwitcher()
◆ ~OgreMaterialSwitcher()
◆ EntityName()
std::string EntityName ( const ignition::math::Color &  _color) const
[in]_colorThe entity's color.
◆ handleSchemeNotFound()
virtual Ogre::Technique* handleSchemeNotFound ( uint16_t  _schemeIndex,
const Ogre::String &  _schemeName,
Ogre::Material *  _originalMaterial,
uint16_t  _lodIndex,
const Ogre::Renderable *  _rend
[in]_schemeIndexIndex of scheme requested
[in]_schemeNameName of scheme requested
[in]_originalMaterialOrignal material that does not contain the requested scheme
[in]_lodIndexThe material level-of-detail
[in]_rendPointer to the Ogre::Renderable object requesting the use of the techinique
The Ogre material technique to use when scheme is not found.
◆ postRenderTargetUpdate()
virtual void postRenderTargetUpdate ( const Ogre::RenderTargetEvent &  _evt)
[in]_evtOgre render target event containing information about the source render target.
◆ preRenderTargetUpdate()
virtual void preRenderTargetUpdate ( const Ogre::RenderTargetEvent &  _evt)
◆ Reset()
void Reset ( )
