| virtual | ~OgrePointLight () |
| virtual | ~BasePointLight () |
| virtual | ~PointLight () |
| | Deconstructor. More...
| virtual | ~Light () |
| virtual | ~Node () |
| | Destructor. More...
| virtual | ~OgreLight () |
| virtual double | AttenuationConstant () const |
| | Get the attenuation constant value. More...
| virtual double | AttenuationLinear () const |
| | Get the attenuation linear value. More...
| virtual double | AttenuationQuadratic () const |
| | Get the attenuation quadratic value. More...
| virtual double | AttenuationRange () const |
| | Get the attenuation range. More...
| virtual bool | CastShadows () const |
| | Determine if this light cast shadows. More...
| virtual void | Destroy () |
| virtual math::Color | DiffuseColor () const |
| | Get the diffuse color. More...
| virtual Ogre::Light * | Light () const |
| virtual void | SetAttenuationConstant (double _value) |
| | Set the attenuation constant value. More...
| virtual void | SetAttenuationLinear (double _value) |
| | Set the attenuation linear value. More...
| virtual void | SetAttenuationQuadratic (double _value) |
| | Set the attenuation quadratic value. More...
| virtual void | SetAttenuationRange (double _range) |
| | Set the attenuation range. More...
| virtual void | SetCastShadows (bool _castShadows) |
| | Specify if this light should cast shadows. More...
| virtual void | SetDiffuseColor (const math::Color &_color) |
| | Set the diffuse color. More...
| virtual void | SetSpecularColor (const math::Color &_color) |
| | Set the specular color. More...
| virtual math::Color | SpecularColor () const |
| | Get the specular color. More...
| virtual | ~BaseLight () |
| virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) |
| virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0) |
| virtual | ~OgreNode () |
| virtual | ~BaseNode () |
| virtual bool | InheritScale () const override=0 |
| virtual math::Vector3d | LocalScale () const override=0 |
| virtual NodePtr | Parent () const override=0 |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
