OgreRenderTargetMaterial Class Reference
Causes all objects in a scene to be rendered with the same material when rendered by a given RenderTarget. More...
#include <OgreRenderTargetMaterial.hh>
 OgreRenderTargetMaterial (OgreScenePtr _scene, Ogre::RenderTarget *_renderTarget, Ogre::Material *_material)
 constructor More...
 ~OgreRenderTargetMaterial ()
 destructor More...
virtual Ogre::Technique * handleSchemeNotFound (uint16_t _schemeIndex, const Ogre::String &_schemeName, Ogre::Material *_originalMaterial, uint16_t _lodIndex, const Ogre::Renderable *_rend) override
 Ogre callback that assigned same material to all renderables when the requested scheme is not found. More...
◆ OgreRenderTargetMaterial()
OgreRenderTargetMaterial ( OgreScenePtr  _scene,
Ogre::RenderTarget *  _renderTarget,
Ogre::Material *  _material
constructor
[in]_scenethe scene manager responsible for rendering
[in]_renderTargetthe RenderTarget this should apply to
[in]_materialthe material to apply to all renderables
◆ ~OgreRenderTargetMaterial()
destructor
◆ handleSchemeNotFound()
virtual Ogre::Technique* handleSchemeNotFound ( uint16_t  _schemeIndex,
const Ogre::String &  _schemeName,
Ogre::Material *  _originalMaterial,
uint16_t  _lodIndex,
const Ogre::Renderable *  _rend
[in]_schemeIndexIndex of scheme requested
[in]_schemeNameName of scheme requested
[in]_originalMaterialOrignal material that does not contain the requested scheme
[in]_lodIndexThe material level-of-detail
[in]_rendPointer to the Ogre::Renderable object requesting the use of the techinique
The Ogre material technique to use when scheme is not found.
