| virtual | ~OgreThermalCamera () |
| | Destructor. More...
| virtual ignition::common::ConnectionPtr | ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| | Connect to the new thermal image signal. More...
| virtual void | CreateRenderTexture () |
| | Create a texture. More...
| | Initialize the camera. More...
| | Render the camera. More...
| | Implementation of the render call. More...
| virtual | ~BaseThermalCamera () |
| | Destructor. More...
| virtual float | AmbientTemperature () const override |
| | Get the ambient temperature of the environment. More...
| virtual float | AmbientTemperatureRange () const override |
| | Get the range of ambient temperature. More...
| virtual float | HeatSourceTemperatureRange () const override |
| | Get the range of temperature variation for all heat sources. More...
| virtual float | LinearResolution () const override |
| | Get the temperature linear resolution. More...
| virtual float | MaxTemperature () const override |
| | Get the maximum temperature the sensor can detect. More...
| virtual float | MinTemperature () const override |
| | Get the minimum temperature the sensor can detect. More...
| virtual void | SetAmbientTemperature (float _ambient) override |
| | Set the ambient temperature of the environment. More...
| virtual void | SetAmbientTemperatureRange (float _range) override |
| | Set the range of ambient temperature. More...
| virtual void | SetHeatSourceTemperatureRange (float _range) override |
| | Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source. More...
| virtual void | SetLinearResolution (float _max) override |
| | Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format. More...
| virtual void | SetMaxTemperature (float _max) override |
| | Set the maximum temperature the sensor can detect. More...
| virtual void | SetMinTemperature (float _min) override |
| | Set the minimum temperature the sensor can detect. More...
| | Destructor. More...
| virtual | ~Camera () |
| | Deconstructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| virtual | ~BaseCamera () |
| virtual VisualPtr | VisualAt (const ignition::math::Vector2i &_mousePos) override |
| virtual | ~OgreSensor () |
| virtual | ~BaseSensor () |
| virtual | ~OgreNode () |
| virtual | ~BaseNode () |
| virtual bool | InheritScale () const override=0 |
| virtual math::Vector3d | LocalScale () const override=0 |
| virtual NodePtr | Parent () const override=0 |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
