An transform tool for translating, rotating, and scaling objects. More...
#include <TransformController.hh>
 TransformController ()
virtual ~TransformController ()
virtual bool Active () const
 Check if the transform process is active. More...
virtual math::Vector3d ActiveAxis () const
 Get the current highlighted active axis of transform. More...
virtual void Attach (NodePtr _node)
 Attach the transform controller to the specified node. More...
virtual math::Vector3d AxisById (unsigned int _id) const
 Get the axis of transform represented by the given node id. More...
virtual CameraPtr Camera () const
 get the camera that is controlled by this view controller. More...
virtual void Detach ()
 Detach the transform controller from the currently attached node. More...
virtual TransformMode Mode () const
virtual NodePtr Node () const
 Get the attached node. More...
virtual void Rotate (const math::Quaterniond &_rotation, bool _snap=false)
 Rotate the attached node. More...
math::Quaterniond RotationFrom2d (const math::Vector3d &_axis, const math::Vector2d &_start, const math::Vector2d &_end)
 Helper function to compute 3d rotation from 2d translation movement. Useful for converting 2d mouse drag motion to rotation angle in world frame. Note that the camera must be set and Start() must be called before using this function. More...
virtual void Scale (const math::Vector3d &_scale, bool _snap=false)
 Scale the attached node. More...
math::Vector3d ScaleFrom2d (const math::Vector3d &_axis, const math::Vector2d &_start, const math::Vector2d &_end)
 Helper function to compute 3d scale from 2d translation movement. Useful for converting 2d mouse drag motion to scale vector in world frame. Note that the camera must be set and Start() must be called before using this function. More...
virtual void SetActiveAxis (const math::Vector3d &_axis)
 Set the active transform axis. This highlights the axis visual. More...
virtual void SetCamera (const CameraPtr &_camera)
 Set the camera. More...
virtual void SetTransformMode (TransformMode _mode)
 Set the transform mode. More...
virtual void SetTransformSpace (TransformSpace _space)
 Set the transform space. More...
virtual TransformSpace Space () const
 Get the transform space. More...
virtual void Start ()
 Start the transform process. To be used with helper functions that computions transforms from 2d movements. More...
virtual void Stop ()
 Stop the transform process. To be used with helper functions that computions transforms from 2d movements. More...
virtual void Translate (const math::Vector3d &_translation, bool _snap=false)
 Translate the attached node. More...
math::Vector3d TranslationFrom2d (const math::Vector3d &_axis, const math::Vector2d &_start, const math::Vector2d &_end)
 Helper function to compute 3d translation from 2d translation movement. Useful for converting 2d mouse drag motion to displacement in world frame. Note that the camera must be set and Start() must be called before using this function. More...
virtual void Update ()
 Update the transform controller. Its visual is updated based on the current transform mode, space, and axis. More...
static ignition::math::Vector3d SnapPoint (const ignition::math::Vector3d &_point, const double _interval=1.0, const double _sensitivity=0.4)
 Snap a point at intervals of a fixed distance. Currently used to give a snapping behavior when transforming objects. More...
static math::Vector3d ToAxis (TransformAxis _axis)
 Convert a TransformAxis to a vector type. More...
Public Attributes
std::unique_ptr< TransformControllerPrivate > dataPtr
 Private data pointer. More...
math::Planed CreatePlaneForTransform (const math::Vector3d &_axis, const math::Vector2d &_pt2d)
 Helper function to create a plane for transfomation. The plane is chosen based on the current transform mode and the transform axis specified. More...
bool RayPlaneIntersection (RayQueryPtr _ray, const math::Planed &_plane, math::Vector3d &_result)
 Helper function to compute ray plane intersection. More...
◆ TransformController()
◆ ~TransformController()
virtual ~TransformController ( )
◆ Active()
virtual bool Active ( ) const
True if node is being transformed
◆ ActiveAxis()
virtual math::Vector3d ActiveAxis ( ) const
Active axis of transform
◆ Attach()
virtual void Attach ( NodePtr  _node)
[in]_nodeNode that will be transformed
◆ AxisById()
virtual math::Vector3d AxisById ( unsigned int  _id) const
[in]_idId of the node to check
Transform axis
◆ Camera()
virtual CameraPtr Camera ( ) const
camera being controlled
◆ CreatePlaneForTransform()
math::Planed CreatePlaneForTransform ( const math::Vector3d &  _axis,
const math::Vector2d &  _pt2d
[in]_axisTransformation axis used to identify the plane for projection.
[in]_pt2d2d point to help fine tune the plane created.
Plane created for transform
◆ Detach()
virtual void Detach ( )
◆ Mode()
virtual TransformMode Mode ( ) const
Transform mode
◆ Node()
virtual NodePtr Node ( ) const
The node which is being transformed, nullptr if there is no node attached.
◆ RayPlaneIntersection()
bool RayPlaneIntersection ( RayQueryPtr  _ray,
const math::Planed &  _plane,
math::Vector3d &  _result
[in]_rayInput ray
[in]_planePlane to check for intersection
[out]_resultIntersection point
True if intersection point exist, false if ray is parallel to plane
◆ Rotate()
virtual void Rotate ( const math::Quaterniond &  _rotation,
bool  _snap = false
[in]_rotationRotation in the current transform space
[in]_snapTrue to snap rotation angle to fixed increments
SetTransformSpace
◆ RotationFrom2d()
math::Quaterniond RotationFrom2d ( const math::Vector3d &  _axis,
const math::Vector2d &  _start,
const math::Vector2d &  _end
[in]_axisAxis of 3d rotation. The resulting rotation is is constrained to this axis.
[in]_startStarting position of the 2d translation movement
[in]_endEnd position of the 2d translation movement
◆ Scale()
virtual void Scale ( const math::Vector3d &  _scale,
bool  _snap = false
[in]_scaleScale in the current transform space
[in]_snapTrue to snap scale to fixed increments
SetTransformSpace
◆ ScaleFrom2d()
math::Vector3d ScaleFrom2d ( const math::Vector3d &  _axis,
[in]_axisAxis of scale. The resulting 3d vector is constrained to this axis.
3d scale vector in the current transform space
◆ SetActiveAxis()
virtual void SetActiveAxis ( const math::Vector3d &  _axis)
[in]_axisTransform axis vector
◆ SetCamera()
virtual void SetCamera ( const CameraPtr &  _camera)
Set the camera.
[in]_cameraCamera
◆ SetTransformMode()
virtual void SetTransformMode ( TransformMode  _mode)
[in]_modeTransform mode to set to
◆ SetTransformSpace()
virtual void SetTransformSpace ( TransformSpace  _space)
[in]_spaceTransform space to set to
◆ SnapPoint()
static ignition::math::Vector3d SnapPoint ( const ignition::math::Vector3d &  _point,
const double  _interval = 1.0,
const double  _sensitivity = 0.4
static
[in]_pointInput point.
[in]_intervalFixed distance interval at which the point is snapped.
[in]_sensitivitySensitivity of point snapping, in terms of a percentage of the interval.
Snapped 3D point.
◆ Space()
virtual TransformSpace Space ( ) const
Transform space
◆ Start()
virtual void Start ( )
Stop
◆ Stop()
virtual void Stop ( )
Stop
◆ ToAxis()
static math::Vector3d ToAxis ( TransformAxis  _axis)
static
3d axis vector
◆ Translate()
virtual void Translate ( const math::Vector3d &  _translation,
bool  _snap = false
[in]_translationTranslation in the current transform space
[in]_snapTrue to snap the final position to fixed increments
SetTransformSpace
◆ TranslationFrom2d()
math::Vector3d TranslationFrom2d ( const math::Vector3d &  _axis,
[in]_axisAxis of 3d translation. The resulting 3d vector is constrained to this axis.
3d translation vector in the current transform space
virtual void Update ( )
◆ dataPtr
std::unique_ptr<TransformControllerPrivate> dataPtr
