DepthCamera.hh
STL class.
Definition: DepthCamera.hh:34
virtual ignition::common::ConnectionPtr ConnectNewRgbPointCloud(std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
Connect to the new rgb point cloud signal.
Definition: Camera.hh:49
virtual const float * DepthData() const =0
All things needed to get back z buffer for depth data.
virtual void CreateDepthTexture()=0
Create a texture which will hold the depth data.
std::function< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> NewFrameListener
Definition: DepthCamera.hh:39
virtual ignition::common::ConnectionPtr ConnectNewDepthFrame(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
Connect to the new depth image signal.
virtual ~DepthCamera()
Definition: DepthCamera.hh:42
