Camera Class Referenceabstract
Posable camera used for rendering the scene graph. More...
#include <ignition/rendering/Camera.hh>
Public Types
virtual ~Camera ()
virtual void Render ()=0
virtual void SetImageFormat (PixelFormat _format)=0
virtual void Update ()=0
virtual VisualPtr VisualAt (const ignition::math::Vector2i &_mousePos)=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
Poseable depth camera used for rendering the scene graph. This camera is designed to produced depth data, instead of a 2D image.
Member Typedef Documentation
◆ NewFrameListener
typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener
◆ ~Camera()
virtual ~Camera ( )
inlinevirtual
◆ AddRenderPass()
Implemented in BaseCamera< T >, and BaseCamera< OgreSensor >.
◆ AntiAliasing()
Implemented in BaseCamera< T >, and OgreCamera.
◆ AspectRatio()
The camera's aspect ratio
◆ Capture()
virtual void Capture ( Image &  _image)
◆ ConnectNewImageFrame()
virtual common::ConnectionPtr ConnectNewImageFrame ( NewFrameListener  _listener)
[in]_listenerNew camera listener callback
◆ Copy()
◆ CreateImage()
virtual Image CreateImage ( ) const
A newly allocated Image for storing this cameras images
Implemented in BaseCamera< T >.
◆ CreateRenderWindow()
Implemented in BaseCamera< T >, BaseCamera< OgreSensor >, and OgreCamera.
◆ FarClipPlane()
virtual double FarClipPlane ( ) const
Far clipping plane distance
◆ FollowOffset()
virtual math::Vector3d FollowOffset ( ) const
Offset of camera from target.
◆ FollowPGain()
virtual double FollowPGain ( ) const
P gain for camera following
◆ FollowTarget()
virtual NodePtr FollowTarget ( ) const
Target node being tracked.
◆ HFOV()
virtual math::Angle HFOV ( ) const
◆ ImageFormat()
virtual PixelFormat ImageFormat ( ) const
The image pixel format
◆ ImageHeight()
The image height in pixels
◆ ImageMemorySize()
virtual unsigned int ImageMemorySize ( ) const
The image memory size in bytes
◆ ImageWidth()
The image width in pixels
◆ NearClipPlane()
virtual double NearClipPlane ( ) const
Near clipping plane distance
◆ PostRender()
virtual void PostRender ( )
Implemented in BaseCamera< T >, BaseCamera< OgreSensor >, OgreGpuRays, and OgreThermalCamera.
◆ Project()
virtual math::Vector2i Project ( const math::Vector3d &  _pt) const
[in]_ptPoint in 3d world space
Point in 2d screen space
◆ ProjectionMatrix()
Camera projection matrix
◆ ProjectionType()
virtual CameraProjectionType ProjectionType ( ) const
Camera projection type
◆ RemoveRenderPass()
◆ Render()
virtual void Render ( )
Implemented in OgreThermalCamera, and OgreCamera.
◆ RenderPassByIndex()
◆ RenderPassCount()
◆ RenderTextureGLId()
Texture Id of type GLuint.
◆ SaveFrame()
virtual bool SaveFrame ( const std::string &  _name)
[in]_nameName of the output file
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetFarClipPlane()
◆ SetFollowOffset()
virtual void SetFollowOffset ( const math::Vector3d &  _offset)
[in]_offsetOffset distance from target node.
◆ SetFollowPGain()
virtual void SetFollowPGain ( const double  _pGain)
[in]_pGainP gain for camera following
◆ SetFollowTarget()
virtual void SetFollowTarget ( const NodePtr &  _target,
const math::Vector3d &  _offset = math::Vector3d::Zero,
const bool  _worldFrame = false
[in]_targetTarget node to follow
[in]_offsetTether the camera at an offset distance from the target node.
[in]_worldFrameTrue to follow the target node at a distance that's fixed in world frame. Default is false which means the camera follows at fixed distance in target node's local frame.
◆ SetHFOV()
◆ SetImageFormat()
virtual void SetImageFormat ( PixelFormat  _format)
[in]_formatNew image pixel format
◆ SetImageHeight()
virtual void SetImageHeight ( unsigned int  _height)
[in]_heightNew image height in pixels
◆ SetImageWidth()
virtual void SetImageWidth ( unsigned int  _width)
[in]_widthNew image width in pixels
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetShadowsDirty()
virtual void SetShadowsDirty ( )
◆ SetTrackOffset()
virtual void SetTrackOffset ( const math::Vector3d &  _offset)
[in]_offsetPoint offset to track
◆ SetTrackPGain()
virtual void SetTrackPGain ( const double  _pGain)
[in]_pGainP gain for camera tracking
◆ SetTrackTarget()
virtual void SetTrackTarget ( const NodePtr &  _target,
[in]_targetTarget node to track
[in]_offsetTrack a point that is at an offset relative to target.
[in]_worldFrameIf true, the offset point to track will be treated in world frame and its position relative to the target node remains fixed regardless of the target node's rotation. Default is false, which means the camera tracks the point in target node's local frame.
◆ TrackOffset()
virtual math::Vector3d TrackOffset ( ) const
Point offset from target.
◆ TrackPGain()
virtual double TrackPGain ( ) const
◆ TrackTarget()
virtual NodePtr TrackTarget ( ) const
virtual void Update ( )
◆ ViewMatrix()
Camera view matrix
◆ VisualAt()
virtual VisualPtr VisualAt ( const ignition::math::Vector2i &  _mousePos)
