SegmentationCamera.hh
17 #ifndef IGNITION_RENDERING_SEGMENTATIONCAMERA_HH_
18 #define IGNITION_RENDERING_SEGMENTATIONCAMERA_HH_
20 #include <functional>
21 #include <string>
22
23 #include <ignition/common/Event.hh>
24 #include <ignition/math/Color.hh>
25
27
28
29 namespace ignition
30 {
31  namespace rendering
32  {
34  enum class SegmentationType
35  {
38  ST_SEMANTIC = 0,
39
42  ST_PANOPTIC = 1
43  };
44
45  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
51  class IGNITION_RENDERING_VISIBLE SegmentationCamera :
52  public virtual Camera
53  {
55  public: virtual ~SegmentationCamera() { }
56
58  public: virtual void CreateSegmentationTexture() = 0;
59
64  public: virtual uint8_t *SegmentationData() const = 0;
65
71  public: virtual ignition::common::ConnectionPtr
72  ConnectNewSegmentationFrame(
73  std::function<void(const uint8_t *, unsigned int, unsigned int,
74  unsigned int, const std::string &)> _subscriber) = 0;
75
78  public: virtual void SetSegmentationType(SegmentationType _type) = 0;
79
82  public: virtual SegmentationType Type() const = 0;
83
87  public: virtual void EnableColoredMap(bool _enable) = 0;
88
91  public: virtual bool IsColoredMap() const = 0;
92
95  public: virtual void SetBackgroundColor(const math::Color &_color) = 0;
96
99  public: virtual void SetBackgroundLabel(int _label) = 0;
100
103  public: virtual const math::Color &BackgroundColor() const = 0;
104
107  public: virtual int BackgroundLabel() const = 0;
108
116  public: virtual void LabelMapFromColoredBuffer(
117  uint8_t *_labelBuffer) const = 0;
118  };
119  }
120  }
121 }
122 #endif
virtual void SetBackgroundLabel(int _label)=0
Set label for background & unlabeled items in the semantic map.
STL class.
STL class.
@ ST_PANOPTIC
Pixels of same label from different items, have different color & id. 1 channel for label id & 2 chan...
Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce s...
Definition: SegmentationCamera.hh:51
Definition: Camera.hh:49
virtual void SetBackgroundColor(const math::Color &_color)=0
Set color for background & unlabeled items in the colored map.
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame(std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
Connect to the new Segmentation image event.
Definition: SegmentationCamera.hh:55
virtual int BackgroundLabel() const =0
Get label for background & unlabeled items in the semantic map.
@ ST_SEMANTIC
Pixels of same label from different items have the same color & id.
virtual void CreateSegmentationTexture()=0
Create a texture which will hold the segmentation data.
virtual bool IsColoredMap() const =0
Check if color map mode is enabled.
virtual void EnableColoredMap(bool _enable)=0
Enable Color map mode to generate colored semantics.
virtual uint8_t * SegmentationData() const =0
Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the...
SegmentationType
Segmentation types for Semantic / Panpoptic segmentation.
Definition: SegmentationCamera.hh:34
virtual const math::Color & BackgroundColor() const =0
Get color for background & unlabeled items in the colored map.
virtual void SetSegmentationType(SegmentationType _type)=0
Set Segmentation Type.
virtual SegmentationType Type() const =0
Get Segmentation Type.
virtual void LabelMapFromColoredBuffer(uint8_t *_labelBuffer) const =0
Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored...
