StoreWrapper< T, U > Class Template Reference
#include <ignition/rendering/StoreWrapper.hh>
| virtual | ~StoreWrapper () |
Public Member Functions inherited from Store< T > | |
| virtual | ~Store () |
| Destructor. More... | |
| virtual bool | Add (TPtr _object)=0 |
| Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done. More... | |
| virtual bool | Contains (ConstTPtr _object) const =0 |
| Determine if store contains the given element. More... | |
| virtual bool | ContainsId (unsigned int _id) const =0 |
| Determine if store contains the element with the given ID. More... | |
| virtual bool | ContainsName (const std::string &_name) const =0 |
| Determine if store contains the element with the given name. More... | |
| virtual void | Destroy (TPtr _object)=0 |
| Remove and destroy given element. If the given element does not exists, in this store, then no work will be done. More... | |
| virtual void | DestroyAll ()=0 |
| Remove and destroy all elements in store. More... | |
| virtual void | DestroyById (unsigned int _id)=0 |
| Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual void | DestroyByIndex (unsigned int _index)=0 |
| Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual void | DestroyByName (const std::string &_name)=0 |
| Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual TPtr | GetById (unsigned int _id) const =0 |
| Get element with the given ID. More... | |
| virtual TPtr | GetByIndex (unsigned int _index) const =0 |
| Get element at the given index. More... | |
| virtual TPtr | GetByName (const std::string &_name) const =0 |
| Get element with the given name. More... | |
| virtual TPtr | Remove (TPtr _object)=0 |
| Remove given element. If the given element does not exists in this store, then no work will be done. More... | |
| virtual void | RemoveAll ()=0 |
| Remove all elements from store. More... | |
| virtual TPtr | RemoveById (unsigned int _id)=0 |
| Remove element with the given ID. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual TPtr | RemoveByIndex (unsigned int _index)=0 |
| Remove element at the given index. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual TPtr | RemoveByName (const std::string &_name)=0 |
| Remove element with the given name. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual unsigned int | Size () const =0 |
| Get number of elements in this store. More... | |
template<class T, class U>
class ignition::rendering::StoreWrapper< T, U >
- Template Parameters
T New storage type U Some derived class of T
◆ ~StoreWrapper()
inlinevirtual |
