BaseInertiaVisual.hh
17 #ifndef IGNITION_RENDERING_BASE_BASEINERTIAVISUAL_HH_
18 #define IGNITION_RENDERING_BASE_BASEINERTIAVISUAL_HH_
21
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  //
34  template <class T>
36  public virtual InertiaVisual,
37  public virtual T
38  {
40  protected: BaseInertiaVisual();
41
43  public: virtual ~BaseInertiaVisual();
44
45  // Documentation inherited.
46  protected: virtual void Init() override;
47
48  // Documentation inherited.
49  protected: virtual void PreRender() override;
50
51  // Documentation inherited.
52  public: virtual void SetInertial(
53  const ignition::math::Inertiald &_inertial) override;
54
55  // Documentation inherited.
56  public: virtual void Load(const ignition::math::Pose3d &,
57  const ignition::math::Vector3d &) override;
58
59  // Documentation inherited
60  public: virtual VisualPtr BoxVisual() const override;
61  };
62
64  template <class T>
66  {
67  }
68
70  template <class T>
72  {
73  }
74
76  template <class T>
78  {
79  T::PreRender();
80  }
81
83  template <class T>
85  {
86  T::Init();
87  }
88
90  template <class T>
92  const ignition::math::Inertiald &_inertial)
93  {
94  auto xyz = _inertial.Pose().Pos();
95  auto q = _inertial.Pose().Rot();
96
97  // Use ignition::math::MassMatrix3 to compute
98  // equivalent box size and rotation
99  auto m = _inertial.MassMatrix();
100  ignition::math::Vector3d boxScale;
102  if (!m.EquivalentBox(boxScale, boxRot))
103  {
104  // Invalid inertia, load with default scale
105  ignlog << "The link is static or has unrealistic "
106  << "inertia, so the equivalent inertia box will not be shown.\n";
107  }
108  else
109  {
110  // Apply additional rotation by boxRot
111  this->Load(ignition::math::Pose3d(xyz, q * boxRot), boxScale);
112  }
113  }
114
116  template <class T>
118  const ignition::math::Vector3d &)
119  {
120  // no op
121  }
122
124  template <class T>
126  {
127  return nullptr;
128  }
129  }
130  }
131 }
132 #endif
Get the box visual.
Definition: BaseInertiaVisual.hh:125
#define ignlog
BaseInertiaVisual()
Definition: BaseInertiaVisual.hh:65
Definition: BaseInertiaVisual.hh:71
Base implementation of an inertia visual.
Definition: BaseInertiaVisual.hh:35
virtual void SetInertial(const ignition::math::Inertiald &_inertial) override
Set the inertial component of the visual.
Definition: BaseInertiaVisual.hh:91
Definition: BaseInertiaVisual.hh:84
Definition: BaseInertiaVisual.hh:77
Represents a inertia visual.
Definition: InertiaVisual.hh:35
const MassMatrix3< T > & MassMatrix() const
virtual void Load(const ignition::math::Pose3d &, const ignition::math::Vector3d &) override
Load the Inertia visual from its pose and scale.
Definition: BaseInertiaVisual.hh:117
const Pose3< T > & Pose() const
