BaseInertiaVisual< T > Class Template Reference
Base implementation of an inertia visual. More...
#include <BaseInertiaVisual.hh>
virtual ~BaseInertiaVisual ()
virtual VisualPtr BoxVisual () const override
 Get the box visual. More...
virtual void Load (const ignition::math::Pose3d &, const ignition::math::Vector3d &) override
virtual void SetInertial (const ignition::math::Inertiald &_inertial) override
virtual ~InertiaVisual ()
template<class T>
class ignition::rendering::BaseInertiaVisual< T >
◆ BaseInertiaVisual()
BaseInertiaVisual ( )
◆ ~BaseInertiaVisual()
~BaseInertiaVisual ( )
◆ BoxVisual()
VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Implements InertiaVisual.
Reimplemented in OgreInertiaVisual, and Ogre2InertiaVisual.
void Init ( )
◆ Load()
void Load ( const ignition::math::Pose3d &  _pose,
const ignition::math::Vector3d &  _scale
Referenced by BaseInertiaVisual< Ogre2Visual >::SetInertial().
void PreRender ( )
◆ SetInertial()
void SetInertial ( const ignition::math::Inertiald &  _inertial)
