Camera.hh
17 #ifndef IGNITION_RENDERING_CAMERA_HH_
18 #define IGNITION_RENDERING_CAMERA_HH_
20 #include <string>
21
22 #include <ignition/common/Event.hh>
23 #include <ignition/math/Matrix4.hh>
24
25 #include "ignition/rendering/config.hh"
30
31
32 namespace ignition
33 {
34  namespace rendering
35  {
36  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
37  //
39  enum IGNITION_RENDERING_VISIBLE CameraProjectionType
40  {
45  };
46
49  class IGNITION_RENDERING_VISIBLE Camera :
50  public virtual Sensor
51  {
53  public: typedef std::function<void(const void*, unsigned int,
54  unsigned int, unsigned int, const std::string&)> NewFrameListener;
55
57  public: virtual ~Camera() { }
58
61  public: virtual unsigned int ImageWidth() const = 0;
62
65  public: virtual void SetImageWidth(unsigned int _width) = 0;
66
69  public: virtual unsigned int ImageHeight() const = 0;
70
73  public: virtual void SetImageHeight(unsigned int _height) = 0;
74
78  public: virtual PixelFormat ImageFormat() const = 0;
79
82  public: virtual void SetImageFormat(PixelFormat _format) = 0;
83
86  public: virtual unsigned int ImageMemorySize() const = 0;
87
90  public: virtual math::Angle HFOV() const = 0;
91
94  public: virtual void SetHFOV(const math::Angle &_hfov) = 0;
95
98  public: virtual double AspectRatio() const = 0;
99
104  public: virtual void SetAspectRatio(const double _ratio) = 0;
105
106  // TODO(anyone): add auto-aspect ratio
107
110  public: virtual unsigned int AntiAliasing() const = 0;
111
117  public: virtual void SetAntiAliasing(const unsigned int _aa) = 0;
118
121  public: virtual double FarClipPlane() const = 0;
122
125  public: virtual void SetFarClipPlane(const double _far) = 0;
126
129  public: virtual double NearClipPlane() const = 0;
130
133  public: virtual void SetNearClipPlane(const double _near) = 0;
134
138  public: virtual void Render() = 0;
139
144  public: virtual void PostRender() = 0;
145
148  // \return visual for that position, null if no visual was found
149  public: virtual VisualPtr VisualAt(const ignition::math::Vector2i
150  &_mousePos) = 0;
151
157  public: virtual void Update() = 0;
158
164  public: virtual Image CreateImage() const = 0;
165
172  public: virtual void Capture(Image &_image) = 0;
173
179  public: virtual void Copy(Image &_image) const = 0;
180
186  public: virtual bool SaveFrame(const std::string &_name) = 0;
187
190  public: virtual common::ConnectionPtr ConnectNewImageFrame(
191  NewFrameListener _listener) = 0;
192
195  public: virtual RenderWindowPtr CreateRenderWindow() = 0;
196
199  public: virtual math::Matrix4d ProjectionMatrix() const = 0;
200
203  public: virtual math::Matrix4d ViewMatrix() const = 0;
204
208  public: virtual void SetProjectionMatrix(const math::Matrix4d &_matrix)
209  = 0;
210
213  public: virtual CameraProjectionType ProjectionType() const = 0;
214
223  public: virtual void SetProjectionType(CameraProjectionType _type) = 0;
224
228  public: virtual math::Vector2i Project(const math::Vector3d &_pt) const
229  = 0;
230
243  public: virtual void SetTrackTarget(const NodePtr &_target,
244  const math::Vector3d &_offset = math::Vector3d::Zero,
245  const bool _worldFrame = false) = 0;
246
249  public: virtual NodePtr TrackTarget() const = 0;
250
255  public: virtual void SetTrackOffset(const math::Vector3d &_offset) = 0;
256
260  public: virtual math::Vector3d TrackOffset() const = 0;
261
265  public: virtual void SetTrackPGain(const double _pGain) = 0;
266
269  public: virtual double TrackPGain() const = 0;
270
282  public: virtual void SetFollowTarget(const NodePtr &_target,
283  const math::Vector3d &_offset = math::Vector3d::Zero,
284  const bool _worldFrame = false) = 0;
285
288  public: virtual NodePtr FollowTarget() const = 0;
289
294  public: virtual void SetFollowOffset(const math::Vector3d &_offset) = 0;
295
299  public: virtual math::Vector3d FollowOffset() const = 0;
300
304  public: virtual void SetFollowPGain(const double _pGain) = 0;
305
308  public: virtual double FollowPGain() const = 0;
309
312  public: virtual void SetMaterial(const MaterialPtr &_material) = 0;
313
318  public: virtual unsigned int RenderTextureGLId() const = 0;
319
326  public: virtual void RenderTextureMetalId(void *_textureIdPtr) const = 0;
327
330  public: virtual void AddRenderPass(const RenderPassPtr &_pass) = 0;
331
334  public: virtual void RemoveRenderPass(const RenderPassPtr &_pass) = 0;
335
338  public: virtual unsigned int RenderPassCount() const = 0;
339
342  public: virtual RenderPassPtr RenderPassByIndex(unsigned int _index)
343  const = 0;
344
347  public: virtual void SetShadowsDirty() = 0;
348  };
349  }
350  }
351 }
352 #endif
Definition: Sensor.hh:32
Enum for projection types.
Definition: Camera.hh:39
Perspective projection.
Definition: Camera.hh:42
STL class.
Definition: Image.hh:36
Orthographic projection.
Definition: Camera.hh:44
std::function< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> NewFrameListener
Definition: Camera.hh:54
PixelFormat
Image pixel format types.
Definition: PixelFormat.hh:32
virtual ~Camera()
Definition: Camera.hh:57
Definition: Camera.hh:49
static const Vector3 Zero
