Sensor Class Referenceabstract
#include <ignition/rendering/Sensor.hh>
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
| Destructor. More... | |
◆ ~Sensor()
inlinevirtual |
References Sensor::SetVisibilityMask(), and Sensor::VisibilityMask().
◆ SetVisibilityMask()
pure virtual |
[in] _mask Visibility mask
Implemented in Ogre2Camera, OgreCamera, BaseSensor< T >, BaseSensor< Ogre2Node >, and BaseSensor< OgreNode >.
Referenced by Sensor::~Sensor().
◆ VisibilityMask()
pure virtual |
- Returns
- visibility mask
Implemented in BaseSensor< T >, BaseSensor< Ogre2Node >, and BaseSensor< OgreNode >.
