BaseMaterialMap< T > Class Template Reference
#include <BaseRenderTypes.hh>
Public Member Functions inherited from BaseMap< Material, T > | |
| BaseMap () | |
| virtual | ~BaseMap () |
| virtual bool | ContainsKey (const std::string &_key) const |
| Determine if an elements is mapped to the given key. More... | |
| virtual bool | ContainsValue (ConstTPtr _value) const |
| Determine if the given element exists in this map. More... | |
| virtual UPtr | Derived (const std::string &_key) const |
| virtual UPtr | DerivedByIndex (unsigned int _index) const |
| virtual TPtr | Get (const std::string &_key) const |
| Get the element mapped to the given key. More... | |
| virtual TPtr | GetByIndex (unsigned int _index) const |
| Get the element at the given index. More... | |
| virtual bool | Put (const std::string &_key, TPtr _value) |
| Map to given element to the given key. If the given key is already in use, no work will be done. More... | |
| virtual void | Remove (const std::string &_key) |
| Remove the element mapped to the given key. If the specified element does not exists, no work will be done. More... | |
| virtual void | Remove (TPtr _value) |
| Remove the given element. If the given element does not exist no work will be done. More... | |
| virtual void | RemoveAll () |
| Remove all elements from this map. More... | |
| virtual unsigned int | Size () const |
| Get the number of elements in this map. More... | |
Public Member Functions inherited from Map< Material > | |
| virtual | ~Map () |
| Destructor. More... | |
Protected Member Functions inherited from BaseMap< Material, T > | |
| virtual bool | IsValidIter (ConstUIter _iter) const |
Protected Attributes inherited from BaseMap< Material, T > | |
| UMap | map |
