BaseRenderPass< T > Class Template Reference
Base render pass that can be applied to a render target. More...
#include <BaseRenderPass.hh>
| virtual | ~BaseRenderPass () |
| Destructor. More... | |
| virtual bool | IsEnabled () const override |
| virtual void | SetEnabled (bool _enabled) override |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
| BaseRenderPass () | |
| Constructor. More... | |
Protected Attributes | |
| bool | enabled = true |
| Flag to indicate if render pass is enabled or not. More... | |
template<class T>
class ignition::rendering::BaseRenderPass< T >
◆ BaseRenderPass()
protected |
◆ ~BaseRenderPass()
virtual |
◆ IsEnabled()
overridevirtual |
- Returns
- True if the render pass is enabled, false otherwise.
Implements RenderPass.
◆ SetEnabled()
overridevirtual |
[in] _enabled True to enable the render pass, false to disable.
◆ enabled
protected |
Referenced by BaseRenderPass< OgreObject >::IsEnabled(), and BaseRenderPass< OgreObject >::SetEnabled().
