#include <GaussianNoisePass.hh>
| GaussianNoisePass () | |
| Constructor. More... | |
| virtual | ~GaussianNoisePass () |
| Destructor. More... | |
| virtual double | Bias () const =0 |
| Accessor for bias. More... | |
| virtual double | Mean () const =0 |
| Accessor for mean. More... | |
| virtual void | SetBiasMean (double _biasMean)=0 |
| Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| virtual void | SetBiasStdDev (double _biasStdDev)=0 |
| Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| virtual void | SetMean (double _mean)=0 |
| Set mean. More... | |
| virtual void | SetStdDev (double _stdDev)=0 |
| Set stddev. More... | |
| virtual double | StdDev () const =0 |
| Accessor for stddev. More... | |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
| virtual bool | IsEnabled () const =0 |
| virtual void | SetEnabled (bool _enabled)=0 |
◆ GaussianNoisePass()
◆ ~GaussianNoisePass()
virtual |
◆ Bias()
pure virtual |
Accessor for bias.
- Returns
- Bias on output.
Implemented in BaseGaussianNoisePass< T >, BaseGaussianNoisePass< OgreRenderPass >, and BaseGaussianNoisePass< Ogre2RenderPass >.
◆ Mean()
pure virtual |
Accessor for mean.
- Returns
- Mean of Gaussian noise.
◆ SetBiasMean()
pure virtual |
- See also
- SetBiasStdDev
◆ SetBiasStdDev()
pure virtual |
- See also
- SetBiasMean
◆ SetMean()
pure virtual |
Set mean.
[in] _mean Mean of Gaussian noise.
◆ SetStdDev()
pure virtual |
Set stddev.
[in] _stdDev Standard deviation of Gaussian noise.
◆ StdDev()
pure virtual |
- Returns
- Standard deviation of Gaussian noise.
