HeightmapDescriptor Class Reference
Describes how a Heightmap should be loaded. More...
#include <HeightmapDescriptor.hh>
 HeightmapDescriptor ()
 HeightmapDescriptor (const HeightmapDescriptor &_desc)
 Copy constructor. More...
 HeightmapDescriptor (HeightmapDescriptor &&_desc) noexcept
 Move constructor. More...
virtual ~HeightmapDescriptor ()
void AddBlend (const HeightmapBlend &_blend)
 Add a heightmap blend. More...
void AddTexture (const HeightmapTexture &_texture)
 Add a heightmap texture. More...
const HeightmapBlend * BlendByIndex (uint64_t _index) const
 Get a heightmap blend based on an index. More...
uint64_t BlendCount () const
 Get the number of heightmap blends. More...
std::shared_ptr< common::HeightmapData > Data () const
 Get the heightfield data. More...
 Get the heightmap's name used for caching. This is different from its unique Heightmap::Name(). More...
HeightmapDescriptor & operator= (HeightmapDescriptor &&_desc)
 Move assignment operator. More...
HeightmapDescriptor & operator= (const HeightmapDescriptor &_desc)
 Copy Assignment operator. More...
ignition::math::Vector3d Position () const
 Get the heightmap's position offset. More...
unsigned int Sampling () const
 Get the heightmap's sampling per datum. More...
void SetData (const std::shared_ptr< common::HeightmapData > &_data)
 Set the heightfield data. More...
void SetName (const std::string &_name)
 Set the heightmap's name. More...
void SetPosition (const ignition::math::Vector3d &_position)
 Set the heightmap's position offset. More...
void SetSampling (unsigned int _sampling)
 Set the heightmap's sampling. Defaults to 1. More...
void SetSize (const ignition::math::Vector3d &_size)
 Set the heightmap's scaling factor. Defaults to 1x1x1. More...
void SetUseTerrainPaging (bool _use)
 Set whether the heightmap uses terrain paging. Defaults to false. More...
ignition::math::Vector3d Size () const
 Get the heightmap's scaling factor. More...
const HeightmapTexture * TextureByIndex (uint64_t _index) const
 Get a heightmap texture based on an index. More...
uint64_t TextureCount () const
 Get the number of heightmap textures. More...
bool UseTerrainPaging () const
 Get whether the heightmap uses terrain paging. More...
ignition/rendering/HeightmapDescriptor.hh
◆ HeightmapDescriptor() [1/3]
◆ HeightmapDescriptor() [2/3]
Copy constructor.
[in]_descHeightmapDescriptor to copy.
◆ HeightmapDescriptor() [3/3]
HeightmapDescriptor ( HeightmapDescriptor &&  _desc)
noexcept
Move constructor.
[in]_descHeightmapDescriptor to move.
◆ ~HeightmapDescriptor()
virtual ~HeightmapDescriptor ( )
◆ AddBlend()
void AddBlend ( const HeightmapBlend &  _blend)
[in]_blendBlend to add.
◆ AddTexture()
void AddTexture ( const HeightmapTexture &  _texture)
[in]_textureTexture to add.
◆ BlendByIndex()
const HeightmapBlend* BlendByIndex ( uint64_t  _index) const
[in]_indexIndex of the heightmap blend. The index should be in the range [0..BlendCount()).
Pointer to the heightmap blend. Nullptr if the index does not exist.
uint64_t BlendCount() const
◆ BlendCount()
uint64_t BlendCount ( ) const
Number of heightmap blends contained in this Heightmap object.
◆ Data()
Heightmap data.
◆ Name()
const std::string& Name ( ) const
Heightmap's given name. Defaults to Heightmap::Name().
◆ operator=() [1/2]
HeightmapDescriptor& operator= ( HeightmapDescriptor &&  _desc)
Reference to this.
◆ operator=() [2/2]
HeightmapDescriptor& operator= ( const HeightmapDescriptor &  _desc)
[in]_descThe heightmap to set values from.
*this
◆ Position()
ignition::math::Vector3d Position ( ) const
The heightmap's position offset.
◆ Sampling()
unsigned int Sampling ( ) const
The heightmap's sampling.
◆ SetData()
void SetData ( const std::shared_ptr< common::HeightmapData > &  _data)
[in]_dataNew data.
◆ SetName()
void SetName ( const std::string &  _name)
[in]_nameHeightmap's name.
◆ SetPosition()
void SetPosition ( const ignition::math::Vector3d &  _position)
◆ SetSampling()
void SetSampling ( unsigned int  _sampling)
[in]_samplingThe heightmap's sampling per datum.
◆ SetSize()
void SetSize ( const ignition::math::Vector3d &  _size)
The heightmap's size factor.
◆ SetUseTerrainPaging()
void SetUseTerrainPaging ( bool  _use)
[in]_useTrue to use.
◆ Size()
ignition::math::Vector3d Size ( ) const
The heightmap's size.
◆ TextureByIndex()
const HeightmapTexture* TextureByIndex ( uint64_t  _index) const
[in]_indexIndex of the heightmap texture. The index should be in the range [0..TextureCount()).
Pointer to the heightmap texture. Nullptr if the index does not exist.
uint64_t TextureCount() const
◆ TextureCount()
uint64_t TextureCount ( ) const
Number of heightmap textures contained in this Heightmap object.
◆ UseTerrainPaging()
bool UseTerrainPaging ( ) const
True if the heightmap uses terrain paging.
